HP 550 schematic
  • Atomdesign
    • Feb 2012
    • 19
    • The Netherlands
    HP 550 schematic
    Hi all. This is my first post here. I won't bother you with my history as far as laptop repairs are concerned, but I want to mention that I have some basic electronics knowledge and just learned how to somewhat understand laptop motherboard schematics.
    The specific issue I wanted to ask about here concerns an HP 550:
    The issue is that the laptop has no backlight. Its not an obvious fix, I've made sure that both LCD and inverter are working properly.
    I found that the problem is on the motherboard.
    I'm in the fortunate situation to have three identical motherboards. One with a functional backlight, the other with a defective backlight and the third with serious moisture damage. I can use that last one to scavenge components.
    Now, I started off by comparing voltages on the LVDSB connector on the motherboard with functioning backlight to those on the defective one.
    I found that one of the pins had a 3.3V on the functional motherbaord, but 0V on the defective one. Using my lab power supply I applied 3.3V to the pin on the defective mobo and got the screen to light up. Bingo.
    The problem is, I want to actually fix the issue and I can't for the life of me figure out which component went bad. It may be a schematic issue, but I can't find a more appropriate one.
    Here's the schematic I'm using:
    The component names match up to what is on the motherboard itself. That is to say - they mostly do. This schematic is for a HP 540, but I tried hard to find one for a 550 and I just can't. To make things more interesting, sometimes I see this same schematic listed as applying also for the HP 550.
    Using the HP 540 schematic I see that the pin with the missing voltage is pin number 9 on connector CN17. This is shown on page 30.
    Looking at where pin 9 goes, it should lead to a Q61. Now that's the issue. There is no Q61 on the motherboard. Trust me, I didn't do a half assed check to find this thing. I looked over the entire motherboard for well over an hour as I was convinced it had to be there. It isn't. I searched for the resistors connected in series with Q61 (R9613 and R9614) but those were nowhere to be found either.
    I did find U28, but its fourth leg is connected to R15, not R9613 like the schematic shows.
    Do I really have the wrong schematic? So many other parts match up perfectly.
    Additional info: The motherboard has the following printed on it:
    6050A2216301-MB-A02
    DYnamic KM-VO
    E25540094V-O
    If I do have the wrong schematic and can't get one, then how should I approach this? I tried checking for continuity between Pin 9 and a stupid amount of nearby and far away components and I couldn't get anything anywhere. I suppose I could find a spot where 3.3V is available and solder a jumper wire to pin 9, but I'm pretty sure that qualifies as a hack job and am uncertain it would work as a long term solution. Besides, it might put too much strain on other components and would keep the lid switch non functional.
    I'm all open for ideas!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP 550 schematic
    one of those should help
    Im Back... sort of...
    • Atomdesign
      • Feb 2012
      • 19
      • The Netherlands
      Thanks for the schematics, but sadly none of the three corresponds to my motherboard.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        try this
        • Atomdesign
          • Feb 2012
          • 19
          • The Netherlands
          Originally posted by ala_borbe
          try this
          The top one of those two is quite close, but its the same one I linked in my original post. Q61 is simply not present on either of the HP550 boards I have.
          • Dimitrios
            • Nov 2013
            • 127
            • Greece
            Hello there AtomDesign! I have the exact same issue and want really to get to the bottom of this! I have also replaced inverter, cables and compatible screen with no avail. Still the same. Picture is on but no sign at all of backlight! I have measured input pins of inverter and can see one pin that has 3.3V and 2 pins that have 19V. Can you tell me your voltages in more detail to be able to compare? Thank you and I will try my best to fix it and help!
            • Dimitrios
              • Nov 2013
              • 127
              • Greece
              An update! I too confirm that the problem lies on pin9 CN17 but cannot find the path. I also find U28 but voltages are not the same as the schemtic. I think in this part it is somewhat wrong! Have a look on my findings!
              • Francisco.s
                • 686
                • Spain
                If you can measure +5S at pin 2 of mosfet pmv65xp, and cero volts at pin 1, you should also have 5 volts at pin 3, otherwise this mosfet (q61) could be already damaged.
                • Dimitrios
                  • Nov 2013
                  • 127
                  • Greece
                  The problem is that I cannot find Q61 no matter how hard I tried. I think the schematics are wrong and without them I am not able to trace pin9 on CN17 that has not backlight on signal. I am thinking to reflow Northbridge since it has also the gpu part inside it!
                  The thread should also be renamed as: HP 550 Backlight off problem...
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    Looks like you reading is off. You got 3.3v at pin3? Or you mean pin 3 is 0v and pin 5 is 3.3 which according to your schematic is connected to +V5S?
                    You can trace where LCM_BKLTEN is coming from and find out why it is giving you 5v. If the output of the NAND gate is 5v at pin 4 of U28, Q61 will turn on and gives 5v at its pin 3.
                    • Dimitrios
                      • Nov 2013
                      • 127
                      • Greece
                      Thanks for answer. The reading is correct and taken when laptop was in power ON. My guide was the official pinout that I embedded below of the chip. The thing is that there is nowhere to be found the rest of the components to try and test them. the LCM_BACKLTEN is coming from Northbridge which also has integrated the GPU. The schematics are wrong in this part (it is from HP 540) but nonetheless the chip should have Ground on pin 3 because of its design. The best thing I can do since I can't find Q61 is a reflow of southbridge and hope that the fault was coming from there...
                      • Francisco.s
                        • 686
                        • Spain
                        In following link you can see some pictures and some information.
                        I think it will help you.
                        http://www.elvikom.pl/forum/viewtopi...984&view=print
                        • Dimitrios
                          • Nov 2013
                          • 127
                          • Greece
                          Thanks for link. They have the same problem though not to be able to find the rest components like Q61. They also suggest that the problem lies on Southbridge like I suspect so I am going ro attempt a proffesional reflow as I have the proper equipment to be done right!
                          • Francisco.s
                            • 686
                            • Spain
                            One of the diagrams, Q61 is not mounted, and output from U28 is connected directly to CN17.
                            • Dimitrios
                              • Nov 2013
                              • 127
                              • Greece
                              Did the readings again and are still the same. Even when power off the readings are the same. Two 5V and one 3.3V, one Ground and one 0V maybe the output but on different pins. Both diagrams are the same for U28. Maybe this is faulty??
                              • Dimitrios
                                • Nov 2013
                                • 127
                                • Greece
                                UPDATE:
                                The schematics are wrong because I found that U28 does a completely different job. I traced the resistors around and can confirm that it is a part of battery charging circuit on page 5 of 48 of the file HP Compaq 540 – 6520s – 6720s schematics (Inventec DDD UMA).pdf as is already uploaded on the 4th post.
                                This is a pic of circuit:
                                and the specific diagramm that corresponds to it:
                                You that the voltages are now correct so there is a problem in Northbridge!
                                • dj_ricoh
                                  • 2073
                                  What program do you use to make those markings
                                  • Dimitrios
                                    • Nov 2013
                                    • 127
                                    • Greece
                                    With SnagIt, one of the best screen capturing software!
                                    • Francisco.s
                                      • 686
                                      • Spain
                                      This diagram is the one I am referencing to.
                                      • Dimitrios
                                        • Nov 2013
                                        • 127
                                        • Greece
                                        Yes I know but it does not corresponds to HP 550 motherboard. R9669 is NOT linked with U28 after checking thoroughly with multimeter. U28 is the U6 in diagrams after excessive examination and path tracing with multimeter. Notice that U28 is located in an exact near position between D2 and R15, R45 and C503 like the diagram. Also the voltages are confirmed with my diagram and final conclusion is that U28 is the U6 on diagram. This relation corresponds only to HP 550 motherboard and HP 540 diagram which is the closest but not the same.
                                        • bart64
                                          ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
                                          by bart64
                                          After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
                                          10-18-2025, 05:51 AM
                                        • MakNCheese
                                          ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                                          by MakNCheese
                                          I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                                          Symptoms:
                                          • Severe lag across the system, including BIOS navigation.
                                          • Slow boot times and unresponsive performance in Windows.
                                          • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                                          • No error messages or BSODs, just extreme sluggishness.
                                          What I've Tried:
                                          • Replaced
                                          06-04-2025, 12:48 AM
                                        • totof
                                          Issue on DC/DC chip on Samsung UE55MU9000 motherboard
                                          by totof
                                          I have a problem with my Samsung UE55MU9000T TV, which is out of order. The TV starts up normally, but after about a minute, horizontal lines begin to appear on the screen, and after another minute, only horizontal lines remain.
                                          I noticed that the DC/DC converter on the motherboard (BN41-02570B) gets slightly warm, and when it reaches approximately 43 degrees Celsius, the horizontal lines appear. If I cool the converter with a freeze spray, the lines disappear, but of course, they reappear after a few seconds. I disconnected the LVDS cables and observed that the temperature of the...
                                          11-18-2025, 04:03 PM
                                        • fixme2024
                                          Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
                                          by fixme2024
                                          Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
                                          Here, I have attached a document...
                                          02-14-2024, 09:24 PM
                                        • YOUCEF4787
                                          Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                          by YOUCEF4787
                                          I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                          Initial Problem:
                                          The laptop was completely dead, no signs of life, no power LED.
                                          Action Taken:
                                          I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                          Current Situation & The Main Issue:
                                          The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                          09-21-2025, 12:19 PM
