Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
  • fixme2024
    • Sri Lanka
    Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
    Here, I have attached a document showing how the charging IC voltage is currently functioning. If you could identify a specific location, I can track the issue in a similar manner.
  • bajdik
    Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
    by bajdik
    I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
    Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
    I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
    Unfortunately, I don’t have access to the schematic.
    It seems to me that when I bend the board, something changes.
    Could this...
    08-13-2025, 07:26 AM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • shahnld
    Lenovo legion 5 pro startup issue
    by shahnld
    Good day Experts
    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
    08-24-2025, 12:31 PM
  • ahmarzo
    Acer laptop battery draining issue
    by ahmarzo
    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
    08-02-2025, 06:39 AM
