820-02536 A2681 sch & brd PDF's only
  • Sergio Kub
    • Jul 2018
    • 161
    • Brasil
    #41
    Originally posted by Pedro147
    820-02536 boardview and schematic
    A Chinese friend kindly provided me with 820-02536 board and schematic files today, so I will share them with the community here 2022 A2681 M2 Macbook Air
    Thank You
    • macabook
      • Sep 2024
      • 30
      • France
      #42
      THANKS FOR SHARING
      • DanielDacko
        • Mar 2015
        • 325
        • Macedonia
        #43
        The boardview is pretty innacurate, does anyone else have the proper boardview?
        This is what it shows for LCD connector:
        I don't provide help for people using CH341A and a clip.
        • Federico P
          • Apr 2025
          • 3
          • Argentina
          #44
          Thanks a lot!
          • vinhidalgo
            • Mar 2017
            • 4
            • Costa Rica
            #45
            Hello there!
            I'm trying to download the file but It opens a new page showing: "Invalid File Specified". Any idea on what's wrong?
            Thank you guys.
            Vin
            • Pedro147
              • Sep 2016
              • 158
              Can someone show me how I can re-upload these files, there in no option in in advanced editor. Thanks
              My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
              • Pedro147
                • Sep 2016
                • 158
                Here is a re-upload of these files as they were apparently lost in a data breach
                • DanielDacko
                  • Mar 2015
                  • 325
                  • Macedonia
                  #48
                  Everything in this boardview is PP5V_CHGR, am I the only one who has this problem?
                  • mcthr
                    • Aug 2019
                    • 25
                    • Philippines
                    #49
                    Try this to those who need it,
                    • Pedro147
                      • Sep 2016
                      • 158
                      Not sure what ancient boardview program you are using but there is nothing wrong with the files I uploaded. Maybe start using a decent program like inflex FlexBoardView
                      • Pedro147
                        • Sep 2016
                        • 158
                        Just note that a program like FlexBoardView will work better if you name the folder and boardview / schematic in this format (820-xxxxx) rather than the convoluted naming of your file.
                        By the way, there is nothing wrong with the last file set that I uploaded, I assume it's the boardviewer that he is using
                        • Sergio Kub
                          • Jul 2018
                          • 161
                          • Brasil
                          #52
                          Thank you so much ! Generous
                          • mferna14
                            MacBook Air A2681 battery problem after Screen Replacement
                            by mferna14
                            Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                            12-06-2024, 08:10 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • kuba2102
                            Macbook Air M2 A2681 NAND upgrade error 35
                            by kuba2102
                            Hello people. I have undertaken an upgrade from 256GB to 512GB. I have another A2681 board that I sourced NANDs, resistors and capacitors from. Yet when I try to restore the firmware in FDU mode I get the error 0x23 (35) (error formatting the NAND). Could it be the faulty NAND or I have missed something? Thank you...
                            07-03-2025, 12:20 PM
                          • Dylan Jones
                            MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
                            by Dylan Jones
                            I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
                            I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
                            06-28-2025, 05:07 PM
                          • iMuhtaseb
                            A2681 Keyboard, trackpad and sleep?!
                            by iMuhtaseb
                            Wow it's been a while since I posted!
                            This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
                            A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
                            It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
                            Tested another locked logic board on customer's top case and it posted with keyboard and...
                            05-22-2025, 09:59 AM
