I really appreciate it. Thank you.
820-02536 A2681 sch & brd PDF's only
by mferna14Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
by kais99399Hi everyone
I have a A2681 M2 with a weird charging issue. 3 days working on it without any success . It’s only pulling 5V 0.20A on the USB-C metmeter. The macbook actually boots and reaches the login screen only with the battery connected. If I try to run it on the charger alone (battery disconnected), it doesn't boot at all. My known-good board boots fine on the charger without a battery.
What I've found so far:
Battery Rail connector : Ppvbat_aon_conn. Diode mode is 1830
First usb C When I plug cable power, I measure volt at the fuse F5200 seid ppbus_aon... -
by TimScrawnI have an m2 air A2681 here today that is just giving 5v @ 0.025amp draw. No liquid damage or prior history of repairs. No power at all. Checked the following lines:
PPDCIN_AON_CHGR = 5V
PPBUS_AON = 12.36v
PPBUS_5vS2_VIN = 12.3v
PPBUS_3v3_S2_VIN = 12.3v
PP3V8_ON = 3.8v
PP1V05_S2SW_VDD2H = 0v
PP1V25_S2 = 0v
I have replaced U5200, R5215 & R5216. Checked ohms on both resistors. Both tested good. Little bit stumped on this one. Any help would be greatly appreciated. -
by MarpolexHi I'm having a weird issue with a2681, everything works besides detecting usb-c charger and charging while turned on. So it is charging while its off (turned off ,not lid closed) if i disconnect battery it starts to detect charger while turned on also if I connect 5v while turned off it takes 0.45A and when powered on it stays that way and charger is been detected. No visible liquid damage....
by boysethhello mates,, need help im a new tech here.. any tips or idea on important testpoint in repairing a no power Macbook m2 A2681? Thank you in advance..
- Loading...
