lenovo legion 5-15ach6h bios request
  • eggcap17
    • Dec 2016
    • 3
    • philippines
    #141
    hello,
    need default bios of Legion 5-15ACH6H r70002021 type: 82JW00C4CD S/N: PF45D7CG MO:PFNXB2A13006
    no boot up just blackscreen, lights on keyboard then turns off only light in power button on,fans spinning.
    thank you
    • LBTT1121
      • Nov 2024
      • 687
      • Việt Nam
      #142
      Originally posted by eggcap17
      hello,
      thank you
      hi, try and feedback
      • eggcap17
        • Dec 2016
        • 3
        • philippines
        #143
        thanks but still no luck 😭 turn on then keyboard light turns on then off only power button has white light fans spins but no boot/display. i did it again the keyboard and power button lights turns on and 3 seconds turn off then turns on again and same again no boot up/display.
        • anthony perez sanchez
          • Jan 2025
          • Chile
          #144
          Hi, I've been reading the forum and I know that before I ask my question I need to give all the necessary information, so before I ask my full question could you tell me how I can find the following data:
          Serial: PF39977K
          Model name: Legion 5 15ACH6H
          Main Board: NM-D562 Rev:3
          BIOS: 74M12JWS1Q (W25Q128FW), (UB3, 16MB)
          BIOS : W25Q16DW (UG10, 2MB)
          This is an example of what I saw, it's not from my PC, but I would like to know how I can find that data on my PC​
          • peste
            • Dec 2016
            • 13333
            • ROMANIA
            #145
            Serial: PF39977K
            you have a label on the laptop case for the name and model S/N, etc.. for the motherboard model you have to open your laptop and it is written on the motherboard usually with white paint, there you will also find the bios chips.. for writing or flashing the content on the chip ...ou need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
            • shahnld
              • Nov 2019
              • 164
              • Netherlands
              #146
              Good Day.
              I need bios for lenovo legion pro 5 16ACH6H ryzen 5800H, rtx 3070laptop Gpu,.laptop goes on but gives blank screen with back light on and in this state no image via hdmi also,. 1 in 40 times it does display an image and then it works fine untill restarted,. i dont know if its bios issue but to be sure want to flash it, dump is attached,
              serialNR: PF3CZV7N
              Kind regards
                SMDFlea commented
                Editing a comment
                Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
            • shahnld
              • Nov 2019
              • 164
              • Netherlands
              #147
              Guess merged post does not get helped .? Just curious..
              • volinakis
                • Jan 2021
                • 2869
                • N/A
                #148
                Originally posted by shahnld
                Good Day.
                serialNR: PF3CZV7N
                Kind regards
                try. Be patient, we are doing this for free and on our free time.
                • shahnld
                  • Nov 2019
                  • 164
                  • Netherlands
                  #149
                  Thanks.. I understand it and i was'nt complaining, i shared a thought.. by the way. I saw a donation link in one of my post and later it just disappeared..? Is there a permanent link for donations..?
                  Cheers
                  • volinakis
                    • Jan 2021
                    • 2869
                    • N/A
                    #150
                    Cheers
                    it worked the file I sent you?
                    • shahnld
                      • Nov 2019
                      • 164
                      • Netherlands
                      #151
                      I have not flashed yet. Will report after flashing..
                      • shahnld
                        • Nov 2019
                        • 164
                        • Netherlands
                        #152
                        Flashed it. Bios works but the issue did not resolved..si there is some other issue..
                          • Jan 2025
                          • Chile
                          #153
                          Serial: PF3A60HW
                          Model name: Legion 5 Pro-16ACH6H
                          Winbond: 74M12JWS1Q, 25Q16JWN1Q
                          When I opened the PC I saw that there are two chips that say Winbond, do I have to install the BIOS on both? Or is there a thread that explains how to flash a Legion 5 Pro-16ACH6H?
                          Will the ch341a programmer work for my PC? I have read in other threads that they use it for the normal Lenovo Legion 5, but I don't know if it will work for the pro
                          • peste
                            • Dec 2016
                            • 13333
                            • ROMANIA
                            #154
                            Serial: PF3A60HW
                            I don't know either, I haven't used this programmer..go into the programmer's database (you can find it on the internet) and see if it supports this chip..post both chips..
                            • Nicola P
                              • Jan 2025
                              • 4
                              • Italia
                              #155
                              Hi, my Lenovo Legion 5 15ACH6H laptop,
                              S/N: PF2YWDN8
                              MTM: 82JU0069SP
                              Factory ID: JVHFC1
                              MO: PF9XB1607034
                              when I turn it on the screen stays black and I can't even enter the bios, I need a method to restore the bios, how can I do it? If it can be useful this is its bios
                              • peste
                                peste commented
                                Editing a comment
                                post here not on another site..
                            • shahnld
                              • Nov 2019
                              • 164
                              • Netherlands
                              #156
                              Good day Experts..
                              I need Vbios for lenovo y540, rtx 2060 mobile, gives b32 till b64 errors on B1, nvmt wont read vbios.. replaced b1 yet no change.. main bios is flashed by someone else.. so not sure if that may have caused the issue. Laptop works but code43 on rtx2060..
                              • Nicola P
                                • Jan 2025
                                • 4
                                • Italia
                                #157
                                S/N: PF2YWDN8
                                MTM: 82JU0069SP
                                Factory ID: JVHFC1
                                MO: PF9XB1607034
                                Original bios from Lenovo site
                                • invert
                                  • Jul 2017
                                  • 7
                                  • kiel
                                  #158
                                  why are you deleting my posts?​
                                    • 21582
                                    Because https://www.badcaps.net/forum/troubl...jw#post3567719
                                    You MUST NOT:
                                    • Hijack threads unrelated to your request
                                    • Post a request in multiple threads
                                    • Post a request multiple times
                                    • Post in foreign (non-English) languages
                                    • Share private contact information
                                    • Offer payment of any kind whatsoever
                                    • Bump your thread or post more than once every 48 hours. If you do so
                                      you will receive an infraction
                                    • Post "clean me", "clear bios", "clean bios", "bios need", "clear me" or other such terms
                                    • invert
                                      • Jul 2017
                                      • 7
                                      • kiel
                                      #160
                                      ok, I couldn't find this post. https://www.badcaps.net/forum/troubl...jw#post3567719
                                      • grimacelord
                                        Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                        by grimacelord
                                        Hello there.
                                        I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                        History:
                                        1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                        I searched for this error online and discovered...
                                        03-15-2023, 03:29 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • HammyCheesy
                                        Lenovo ThinkStation P720 BIOS Request
                                        by HammyCheesy
                                        Hello all,
                                        I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                        When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                        Type: 30BB
                                        Model Number: S03600
                                        S/N: MJ07N68C
                                        Things I have tried:
                                        1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                        2. Attempted to boot with just a single CPU...
                                        04-11-2025, 01:02 AM
                                      • sugih1211
                                        request for bios bin lenovo legion 5-15ach6
                                        by sugih1211
                                        hi admin and all. can please give a clean boot bios bin for lenovo legion 5-15ach hy56w hy66w hy76w nm-d931 rev 1.0 cause my legion on but no display. thanks very much.
                                        08-20-2024, 11:52 PM
