lenovo legion 5-15ach6h bios request
  • peste
    replied
    Originally posted by anthony perez sanchez View Post
    Hi, I've been reading the forum and I know that before I ask my question I need to give all the necessary information, so before I ask my full question could you tell me how I can find the following data:
    Serial: PF39977K
    Model name: Legion 5 15ACH6H
    Main Board: NM-D562 Rev:3
    BIOS: 74M12JWS1Q (W25Q128FW), (UB3, 16MB)
    BIOS : W25Q16DW (UG10, 2MB)
    This is an example of what I saw, it's not from my PC, but I would like to know how I can find that data on my PC
    you have a label on the laptop case for the name and model S/N, etc.. for the motherboard model you have to open your laptop and it is written on the motherboard usually with white paint, there you will also find the bios chips.. for writing or flashing the content on the chip ...ou need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
  • anthony perez sanchez
    replied
    Serial: PF39977K
  • eggcap17
    replied
    hi, try and feedback
    thanks but still no luck 😭 turn on then keyboard light turns on then off only power button has white light fans spins but no boot/display. i did it again the keyboard and power button lights turns on and 3 seconds turn off then turns on again and same again no boot up/display.
  • LBTT1121
    replied
    Originally posted by eggcap17 View Post
    hello,
    need default bios of Legion 5-15ACH6H r70002021 type: 82JW00C4CD S/N: PF45D7CG MO:PFNXB2A13006
    no boot up just blackscreen, lights on keyboard then turns off only light in power button on,fans spinning.
    thank you
  • eggcap17
    replied
    hello,
    thank you
  • hardware1
    replied
    Originally posted by Brzobub View Post
    i need bios for Legion 5-15ACH6H Laptop (Lenovo) - Type 82JU, AMD, Serial PF3MEY78. Mainboard NM-D562 Rev.: 2.0
    Bios chip: GigaDevice 25LR128DSIG Bios reader detects it as GD25LQ64C
    Notebooks power up, black screen, fans at 100%
    Current bios in attachment.
    Thank you
    Here is your new file, it's a virgin BIOS from Lenovo with your DMI.
  • Brzobub
    replied
    Thank you
  • clawofdead
    replied
    Originally posted by peste View Post
    it should start without the serial number..
    Sadly nothing with all the Bios from here.
    Probably a shorted gpu since all the rest has voltage even the cpu on his caps.. Anyone has the UG10 vbios maybe? Don't know if I took the good one there is only one here.
  • peste
    replied
    Originally posted by clawofdead View Post
    Already tried sadly.. Do you think the serial number does impact the startup check? Or I have an hardware issue?
  • clawofdead
    replied
    try post #5..
  • peste
    replied
    I got this PC from someone that tried to repair it sadly he erased the UB3, UG10, and changed the EC for a programmed one from china. So the best is to reprogram at least the UB3 and UG10, I guess ?
    I need some help here. I tried all the firmware for UB3 and UG10 from here but nothing worked still, also checked some voltages around and seems like all around my GPU + Vram is 0,001V including the UG10 that doesn't have the 1.8V on pin 8(even with power button pressed).
    In the other side while my charger is plugged I have 1.8V on the bios chip. Around the EC chip 3,3V is present too.
    When I press the power button, I only got the Power Led on the power button and side, no heat CPU/GPU, no fan, no KB light. All I know was that this Laptop was shutdown mid Windows Updates.. 😅
    I don't have any bios file sadly cause the 2 chips are erased. Can someone help me get the right .bin to program it? (I have a CH341A with 1.8V adapter to program those)
    Here is all the specs (ask me if you need more infos):
    Brand: LENOVO
    Product ID/MTM/: 82JU00T0MZ
    SN: PF3EKKQM
    Factory ID: JVHFC1
    MO:PF9XB2227205
    Main Board: HY660 HY561 HY572 HY56C HY57K NM-D562 Rev:2.0(2021-01-25)
    CPU: AMD Ryzen R5-5600H(100-000000296)
    GPU : RTX3060 6GB (GN20-E3-A1)
    EC/KBC: IT8277E-256 BXA (UE1, 256KB)
    BIOS: GD25LR128DSIG, (UB3, 16MB)
    VBIOS : W25Q16JWNIQ (UG10, 2MB)
    try post #5..
  • clawofdead
    replied
    Brand: LENOVO
    SN: PF3EKKQM
    Factory ID: JVHFC1
    MO:PF9XB2227205
  • peste
    replied
    Originally posted by iizik View Post
    Legion 5 Pro-16ACH6H
    serial number PF38L617 any please help with this bios
    thanks
    you have everything you need for the post#5..
  • peste
    commented on 's reply
    post merged..
  • iizik
    replied
    thanks
  • booba
    replied
    Thank you for your efforts. Unfortunately i have de same symptoms..
  • hoaca388
    replied
    Originally posted by booba View Post
    Hi
    Can you help with this dump please ? Power up with short keyboard light blink and no video, cpu and gpu heats up.
    Lenovo Legion 5 15ACH6H, MTM:82JU0065RM, SN:PF3EGY49, MB:NM-D562 REV 2.0, Factory ID : JVHFC1
    CPU Ryzenâ„¢ 5 5600H
    VGA GeForce RTX 3060 6GB GDDR6
    Original bios dump atached
    Thank you
  • booba
    replied
    Hi
    Thank you
  • ninito
    replied
    Originally posted by hoaca388 View Post
    Check hardware , ok file.
    I will, thanks four your support and help Sir.
  • hoaca388
    replied
    Originally posted by ninito View Post
    New information...
    The problem is still there, the motherboard starts up, the light and keyboard light com on, CPU and GPU gradually heat up as if it is working but the screen is black.
    There is no output via HDMI either.
    Caps lock light not responding.
