Thinkpad L13 Gen 2 Password
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1256
    • France
    #41
    Originally posted by Stefan Steff
    Today I have to work with an Thinkpad L13 password remove situation.
    I followed exactly this volinakis guide and it's 90% accurate.
    I must write 00s on position 3. not FF because with FFs I got Error 2204 :System configuration data is invaid.
    Just an observation...
    Big thanks, volinakis!
    thank you for the precision of the 00
    • VHS
      • Oct 2020
      • 13
      Originally posted by psyjamm
      Re: Thinkpad L13 Gen 2 Password
      Here is clear EC dump, you just need to program your EC chip (nuvoton) with Vertyanov programmer) and after that to fill all information like serial number etc..If you can't fill dmi block by Lenovo maintenance utility, here is adresses of these blocks
      Model name located at 0005C000
      SN,type and board number located at 00058000
      I don't have a Vertyanov programmer.
      Is it possible to add or change the boot order in the locked BIOS?
      The machine I have is fine, except it will only boot from the SSD; USB is locked out, so it can't be reloaded.
      • AzickPro
        • Feb 2025
        • Uzbekistan
        #43
        Hi to all, @volinakis​ bro can you help me to make my readed dump file? Lenovo L13 Gen2 Bios Locked laptop
        • peste
          • 13199
          • ROMANIA
          #44
          post S/N, full name and model, motherboard model,etc.
          • pozarek89
            • Jan 2023
            • 9
            • Poland
            #45
            unlocked KBC bin (Intel platform)
            for your information, password is stored bewteen address 0x5E000 - 0x5E200. I'm not sure if it is similar for other models. You can erase it with 0xFF manually also. 0xFF stands for empty memory byte
            • AzickPro
              • Feb 2025
              • Uzbekistan
              #46
              SN: R9-13P9ZL, Lenovo thinkpad L13 Gen2, Type number 20VH-004EUK 2021/07
              • mareecki
                • Jun 2025
                #47
                Hi All,
                Can anyone unlock bios lenovo thinkpad L13 intel i5 10th
                serial R9-0ZE8ZQ
                type number 20r4-S28W00
                • peste
                  • 13199
                  • ROMANIA
                  #48
                  Originally posted by mareecki
                  Hi All,
                  serial R9-0ZE8ZQ
                  post the original contents of the bios chip..
                  • mareecki
                    • Jun 2025
                    #49
                    I tried to use flash programming tool to save bios backup but it stuck on "load failure: security violation.
                    hdd is wiped so do not have an access to windows (windows wont load as well)
                      • 21467
                      You will need an SPI programmer to make a full backup.
                      • RMDUiFT
                        Should I buy a Lenovo Thinkpad E495 with bios password?
                        by RMDUiFT
                        Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                        I have a few questions:
                        • If I would buy this laptop and have
                        08-25-2024, 09:00 AM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • lucaszmn
                        by lucaszmn
                        Problem:
                        Initial Findings:
                        • I concluded that the
                        08-12-2025, 03:01 PM
                      • traxformania
                        TONGFANG "GM7TG7P" Bios Password Problem?
                        by traxformania
                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                        I'm trying to reset my bios without success.
                        I tried :
                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                        11-15-2023, 07:32 AM
                      • tlindi
                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                        by tlindi
                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                        >Read BIOS guides, methods, resources and tools
                        Ack
                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                        Ack
                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                        01-30-2025, 04:26 AM
