asus fx516pc bios dump
No and yes; the GPU seemed to be fried, and I decided to go the route of an NVMe to oculink external GPU. I bought an MSI reference Vega 56 8 GB (undervolted and overclocked vram), the riser, Oculink cable, and the nvme adapter for around 150 dollars, and I just use the laptop as a desktop now. extremely janky, and the performance is like 10% worse than the 3050 ti, but it gets the job done and was way less expensive than getting the entire motherboard replaced or getting the GPU fixed or learning how to fix it myself as a complete beginner, so it was a semi-win in the end. If you are to go about this method (assuming you have the same Asus Tuf F15), I'd recommend getting a new GPU like the Vega 56. Even with undervolting + underclocking, it shows its age, but some of this performance loss could be due to CPU bottleneck as this laptop only has 4c8t. I'd also recommend going with a Nvidia GPU because the AMD Radeon Software is absolute shite IMO, especially with older cards. overall 7/10
Guys i need working bios for fx516pc, no display, fan spin and static backlight
asus fx516pc r 6.0
serial N1NRKD019966029
Thank youAttached FilesComment
Hi need working bios fx516pe and vga bios 3050ti
MODEL: ASUS FX516p
FX516PE-HN004
SN: MCNRKD014672485
CN.34RM
MFD.2021-12
MB:.FX516PC R 6.0
ISSUE: NO START
Thank you
MODEL: ASUS FX516p
FX516p
MB:.FX516PC R 7.0
ISSUE: NO STARTComment
bios no dedectet SSDAttached FilesComment
hi tryAttached FilesComment
Model fx516pe
mothebord fx516pc r6.0
SN MANRKD012064437
problem does not give imageAttached FilesComment
Hello BadCaps, I'm in desperate need to repair my laptop, no POST, current is fine everywhere on the board, responds to power switch, no display then shut down.
This is an Asus FX516RE-HN001T, Motherboard tag: FX516PC MAINBOARD R2.0, Serial Number: M4NRKD038465161.
Here's a dump of the BIOS .bin file.Attached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
- Loading...
