asus fx516pc bios dump
  • Luís Amaral
    • Nov 2013
    • 78
    • Portugal
    #41
    Originally posted by aprilmixtape
    Asus Tuf Dash F15 (FX516PC Rev 4.0)
    another issue has arisen: gpu not detected in bios nor device manager
    S/N: M5NRKD021440183​
    Did you solve the problem ?
    • aprilmixtape
      Cat Millionaire
      • Dec 2024
      • 9
      No and yes; the GPU seemed to be fried, and I decided to go the route of an NVMe to oculink external GPU. I bought an MSI reference Vega 56 8 GB (undervolted and overclocked vram), the riser, Oculink cable, and the nvme adapter for around 150 dollars, and I just use the laptop as a desktop now. extremely janky, and the performance is like 10% worse than the 3050 ti, but it gets the job done and was way less expensive than getting the entire motherboard replaced or getting the GPU fixed or learning how to fix it myself as a complete beginner, so it was a semi-win in the end. If you are to go about this method (assuming you have the same Asus Tuf F15), I'd recommend getting a new GPU like the Vega 56. Even with undervolting + underclocking, it shows its age, but some of this performance loss could be due to CPU bottleneck as this laptop only has 4c8t. I'd also recommend going with a Nvidia GPU because the AMD Radeon Software is absolute shite IMO, especially with older cards. overall 7/10
      • guyandpit
        • Oct 2021
        • 85
        • Philippines
        #43
        Guys i need working bios for fx516pc, no display, fan spin and static backlight
        asus fx516pc r 6.0
        serial N1NRKD019966029
        Thank you​
        • shiyab
          • Sep 2023
          • 1609
          • india
          #44
          asus fx516pc r 6.0
          Thank you​
          hi try
          • guyandpit
            • Oct 2021
            • 85
            • Philippines
            #45
            Originally posted by shiyab
            hi try
            not working my friend. thank you
            • danito
              • Jun 2016
              • 1097
              #46
              asus fx516pc r 6.0
              Thank you​
              try
              • Closer
                • May 2014
                • Russia
                #47
                Hi need working bios fx516pe and vga bios 3050ti
                MODEL: ASUS FX516p
                FX516PE-HN004
                SN: MCNRKD014672485
                CN.34RM
                MFD.2021-12
                MB:.FX516PC R 6.0
                ISSUE: NO START
                Thank you
                • larson1988
                  • Jul 2019
                  • poland
                  #48
                  MODEL: ASUS FX516p
                  FX516p
                  MB:.FX516PC R 7.0
                  ISSUE: NO START
                    SMDFlea commented
                    Editing a comment
                    post the laptop serial number
                • larson1988
                  • Jul 2019
                  • poland
                  #49
                  Originally posted by larson1988
                  MODEL: ASUS FX516p
                  FX516p
                  MB:.FX516PC R 7.0
                  ISSUE: NO START
                  n6nrkd01952322b
                  • larson1988
                    • Jul 2019
                    • poland
                    #50
                    n6nrkd01952322b
                    bios no dedectet SSD
                    • shiyab
                      • Sep 2023
                      • 1609
                      • india
                      #51
                      hi try
                      • larson1988
                        • Jul 2019
                        • poland
                        #52
                        hi try
                        Workig Great !!!!
                        • shiyab
                          • Sep 2023
                          • 1609
                          • india
                          #53
                          Workig Great !!!!
                          post bord part no
                          • cdsh009
                            • Nov 2017
                            • 45
                            • Venezuela
                            #54
                            Model fx516pe
                            mothebord fx516pc r6.0
                            SN MANRKD012064437
                            problem does not give image
                            • Atef A2i
                              • Mar 2022
                              • 16
                              • TUNISIA
                              #55
                              Hello BadCaps, I'm in desperate need to repair my laptop, no POST, current is fine everywhere on the board, responds to power switch, no display then shut down.
                              This is an Asus FX516RE-HN001T, Motherboard tag: FX516PC MAINBOARD R2.0, Serial Number: M4NRKD038465161.
                              Here's a dump of the BIOS .bin file.
                              • BOGOSY77
                                • Aug 2018
                                • 57
                                • PITON
                                #56
                                Originally posted by cacla
                                Re: asus fx516pc bios dump
                                Here
                                THIS BIOS IS VERY GOOD
                                JUST TEST IT
                                THANK YOU.
                                • Fadi Maqboul
                                  • Feb 2019
                                  • 8
                                  • nablus
                                  #57
                                  need bios for x516pc rev 6.0 the serial number :mcnrkd020465498
                                  • peste
                                    • 13599
                                    • ROMANIA
                                    #58
                                    post the contents of the bios chip even if it is corrupted..
                                    • Fadi Maqboul
                                      • Feb 2019
                                      • 8
                                      • nablus
                                      #59
                                      this bios chip not working i can't read the bin file
                                      • peste
                                        • 13599
                                        • ROMANIA
                                        #60
                                        The bios chip must be unsoldered from the board before writing or reading..
                                        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                        solder wires between the programmer and the bios chip..
                                        you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
