asus fx516pc bios dump
  • Fadi Maqboul
    • Feb 2019
    • 8
    • nablus
    #61
    Originally posted by peste
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    fx516pc rev 6.0 the serial number :mcnrkd020465498
    • Fadi Maqboul
      • Feb 2019
      • 8
      • nablus
      #62
      bump
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
