  • DynaxSC
    • Apr 2021
    • 514
    • Poland
    Usually on ASUS boards it worked to program the oldest (first) stock BIOS version into the SPI chip.
    This BIOS looks for a ME in the chipset, and not finding it starts to download the ME image from the SPI chip into the SRAM of the chipset.
    However this board does not start with a stock ME correctly, so it stops after the CPU DRAM LED has been put off, and does not go further. Something in the stock BIOS is missing, or ASUS just implemented some mechanism to make it impossible to activate the ME on a new chipset using a stock image to make our live more costly.
    I also tried to downgrade a dumped BIOS version (v1701) I have to v0402, but 0605 is the last BIOS version which is possible to achieve downgrading. 0402 is not accepted by 0605 to downgrade, and v0605 does not do the job. Bad luck.
    Therefore I desperately search for the first version of the BIOS (v0402) but dumped from a real physical board. Only this first BIOS version has the capability to program the SRAM with a ME.
    It's also possible, that lower versions exist on boards, but are not on the ASUS support site, so any earlier will do also most probably.
    I hope ther is a hamster like me out there, and could make such BIOS available to me, or give me any other hint how the ME can be programmed to the SRAM a different way.
    Also a hint how to make a stock BIOS correctly boot would be of high value.
    Thanks in advance for help.
  • Herbs n spices
    • Jan 2021
    • 37
    I don't have what you're looking for, but I will offer some suggestions: For ASUS z170-z390 there is a UUID and the board serial number that needs to be transferred to the stock ROM, as well as the MAC address if it has an Intel LAN chip. Those values were stored in a GUID that started with FD44... There is a program called FD44 editor that can transfer them. Although for Z590 I don't know if such a thing still exists, or if it would cause what you speak of.
    Some motherboards have a ME maintenance jumper, perhaps you need to short such a jumper to program the ME? I would also carefully inspect to make sure no components around or behind the chipset were damaged in the replacement process.
    • DynaxSC
      • Apr 2021
      • 514
      • Poland
      Thank you for the information. However the issue is more complicated. I know how to transfer the "personalisation data" into a stock Bios, thats not the issue. The problem is, that the mobo with a factory new chipset, and a stock Bios does not boot correctly, it hangs somewhere after the DRAM LED went off. And it does not matter if the Bios is personalized or not. Beside FD44 I even used Intels Flash Image Tool (fit.exe) to impor the stock Bios image and edit the parameters with fit to enable "Software Binding" of PCH with the Bios. The issue is that ASUS had done something in the stock Bios, that prevents a correct boot sequence to be finalized or something is missing in the stock bios. I also compared the bios structure of Bios version 0402 to 0602 an further versions, and 0402 is somehow uniqe, has one more boot section inside. Possible this is just a production Bios, which after first run combined the Bios ME with the chipset, and after this disables the factory mode to normal operation mode (this option is also selectable with fit.exe).
      As I had a personalized bios version 1701, I just downgraded this version to 0602, and this downgraded bios boots normally, however won't activate the ME (bios shows ME Engine version 0.0.0.0.). Unfortunately its not possible any more to downgrade to 0402. So I believe having a personalized version 0402 would make it possible to activate the ME on the board, whereby it is probably still necessary to enable the "Software binding" with fit.exe. This worked for me with several Asus boards already.
      Another idea I had was to cheat the 0602 Bios to make it possible to downgrade to 0402. I found out where the Bios stores its version, and edited v0402 to have version 0602. Unfortunaltely 0602 still refused to downgrade to the cheated 0402 with 0602 version data.
      So I'm at the end of my ideas at the moment and need a new approach, or a personalized 0402 bios.
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • Deniz
        IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
        by Deniz
        Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
        I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
        I had the BIOS cleaned, but the issue was not resolved and there was still no image.
        Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
        After that, I tried to update the...
        01-27-2026, 06:56 AM
        by Vesko356
        08-11-2023, 03:27 AM
