Did you read the comment above,is there something you don`t understand. Type and post the serial number. Try the suggestions . https://www.badcaps.net/forum/troubl...34#post3397534
asus fx516pc bios dump
MODEL: ASUS FX516p
TUP516PE-CS79-CB
SN: MCNRKD018991505
CN.K2SF
MFD.2021-12
MB:.FX516PC R 6.0
ISSUE: NO DISPLAY
hi can someone fix the bios and ec
thanksAttached FilesComment
hi i need working bios or if someone can repair the ori for ASUS FX516p
i have black screen
MB:.FX516PC R 6.0
sn mcnrkd00115848c
thank youAttached FilesComment
Asus Tuf Dash F15 (FX516PC Rev 4.0)
ssd not detected in bios after flashing
S/N: M5NRKD021440183Attached FilesComment
another issue has arisen: gpu not detected in bios nor device manager
Asus FX516PC
motherboard FX516PC R 7.0
SN: N6NRKD01110522C
Power on and black screan
How to disable on board ram memory??Attached FilesLast edited by piszpunta; 01-03-2025, 08:20 AM.Comment
Hello Badcaps friends.. can you help me repair my bios,, Laptop No Display
Model - FX516p
S/N - M8NRKD000341345
BoardCode - FX516PC rev 4.0Attached FilesComment
but this is working bios
tryAttached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
- Loading...
