Did you read the comment above,is there something you don`t understand. Type and post the serial number. Try the suggestions . https://www.badcaps.net/forum/troubl...34#post3397534
					asus fx516pc bios dump
MODEL: ASUS FX516p
TUP516PE-CS79-CB
SN: MCNRKD018991505
CN.K2SF
MFD.2021-12
MB:.FX516PC R 6.0
ISSUE: NO DISPLAY
hi can someone fix the bios and ec
thanksAttached FilesComment
hi i need working bios or if someone can repair the ori for ASUS FX516p
i have black screen
MB:.FX516PC R 6.0
sn mcnrkd00115848c
thank youAttached FilesComment
hi try this new file
Asus Tuf Dash F15 (FX516PC Rev 4.0)
ssd not detected in bios after flashing
S/N: M5NRKD021440183Attached FilesComment
hi try and feedbackAttached FilesComment
working!Attached FilesComment
another issue has arisen: gpu not detected in bios nor device manager
Asus FX516PC
motherboard FX516PC R 7.0
SN: N6NRKD01110522C
Power on and black screan
How to disable on board ram memory??Attached FilesLast edited by piszpunta; 01-03-2025, 08:20 AM.Comment
Hello Badcaps friends.. can you help me repair my bios,, Laptop No Display
Model - FX516p
S/N - M8NRKD000341345
BoardCode - FX516PC rev 4.0Attached FilesComment
your dump is empty cannot copy dmi
but this is working bios
tryAttached FilesComment
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
			by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
			by DynaxSCHi,
Usually on ASUS boards it worked...-
			by AhariHi all,
I...-
 - Loading...
