hi can you help me bydump bios asus fx516pc rev 4.0
asus fx516pc bios dump
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: asus fx516pc bios dump
^^ Seconded. We're here to help. Post bios dump from your motherboard.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: FX516PE need dump
Post the laptop serial number,and bios backup .
.Comment
m5nrkd01766318dpost the laptop serial number,and bios backup .
.Attached FilesComment
fx516peAttached Files↵
https://www.badcaps.net/donateComment
Hi, I have a question about which chip I should read, I have a FX516PC R6.0 and the bios chip is different, so far I have found the chips
Winbond:
25Q16JWNIQ
25R128JVS0
25Q80DVNIG
which I glimpse that one is for vbios (gpu). Another one that has other functions not specific to bios and the 25R128JVS0 of which there are no records not even in winbond or anywhere, I searched and quite a lot, supposedly it is a 25R128JV or at least make a mini reference to it.
On the other hand I bought an ezp2023+ with which I even have the 1.8v adapter in case I need to use it, but I'm very new to this specifically, so I'm quite worried about making a mistake.
I need to do this because somehow the key I put in the bios as administrator no longer works, it does not detect special characters or numbers which prevents me from being able to use it, it is currently a very expensive paperweight. Help me please.Comment
Friends, there is no image in their bios, they booted with another bios but they did not see the nividia graphics card, I see the graphics card in the bios menu, it is from Intel and nvidia.
My graphics card: nvidia geforce rtx3050
thanksLast edited by asliyucegsm; 05-02-2024, 03:07 PM.Comment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
model.asus fx516f
fx516pc-hn023igaming
sn.m8nrkd023146346
cn.xs7j
mfd.2021-08
mainboard.fx516pc r5.0
gpu.nvidia geforce rtx 3050Attached FilesComment
Model fx516pc
mothebord fx516pc r6.0
problem affichageAttached FilesComment
the problem after pragramtion of bios the pc does not detect ssd and when I put its bios it detects ssd
you must post the laptop serial number. Try this - Disable VMD in bios settings or install RST drivers during windows install https://www.asus.com/support/faq/1044458/
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
