Dell XPS 9310 GDA30 LA-J143P bios repair please
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
Every donation made will go towards server fees and maintenance costs. -
hi can someone please try to fix bios please 3 orange 6 white dell logo just rebooting
service tag FBYL373Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello try ....Attached Filesif you find these attachements useful please consider making a small donation to the site
I have spi and I programmeed many bios but unfortunately Service TaG not mach and not workingyou need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
turn on logo, help repack please ST:62L07G3
read the forum rules..
https://www.badcaps.net/forum/troubl...ore-posting
post full name and model, motherboard model, etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
https://www.badcaps.net/donateComment
XPS 13 9310 2-in-1
Service Tag: 62L07G3Attached Filesif you find these attachements useful please consider making a small donation to the site
XPS 13 7390 2-in-1
LA-J851P
sn :9BYJYY2
help me bios !led code 3 yellow 6 whiteAttached Filesif you find these attachements useful please consider making a small donation to the site
hi try and feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi everybody, I have a dell xps 9310
Serial tag: 92mzxd3
EX: 19750601127
Initially came in with amber light turning on only when the power button was pressed. I saved the corrupted bios and used one from this website. It worked for a day and now same issue. Amber light on power button press. Can someone help me? I have attached the first backup bin file i made.Attached Filesif you find these attachements useful please consider making a small donation to the site
Try and Update.Hi everybody, I have a dell xps 9310
Serial tag: 92mzxd3
EX: 19750601127
my laptop has an error: it has power then turns off, repeats continuously
ST: 2NYWCB3
can someone fix this for me?
Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
