Dell XPS 9310 GDA30 LA-J143P bios repair please
  • kuklin2003
    • May 2021
    • 6
    • Россия
    #201
    Friends, please help me make a working BIOS. The laptop hangs on the logo
    LA-J143P
    MODEL P117G
    ST 19P5593
    • kuklin2003
      • May 2021
      • 6
      • Россия
      #202
      LA-J143P
      MODEL P117G
      ST 19P5593
      OLD DUMP
      • LBTT1121
        • Nov 2024
        • 1216
        • Việt Nam
        #203
        OLD DUMP
        try and feedback
        • kuklin2003
          • May 2021
          • 6
          • Россия
          #204
          Originally posted by LBTT1121
          try and feedback
          Thank you, my friend. Your BIOS is completely fine. But it wasn't the issue. I replaced the CPU and everything worked.
          • LBTT1121
            • Nov 2024
            • 1216
            • Việt Nam
            #205
            ok my friend
            • kuklin2003
              • May 2021
              • 6
              • Россия
              #206
              ok my friend
              My friend, I've run into a problem. My Wi-Fi isn't detecting any networks. Could it be a BIOS issue?
              Do you have any other bios?
              • LBTT1121
                • Nov 2024
                • 1216
                • Việt Nam
                #207
                replate WIFI or try bios
                • Uldix
                  • Nov 2025
                  • PT
                  #208
                  Hello! If someone could please help with the bios stuck on the logo, XPS 13 9310
                  ST - 240JP73
                  Extracted version for key attached.
                  • LBTT1121
                    • Nov 2024
                    • 1216
                    • Việt Nam
                    #209
                    ST - 240JP73
                    try and feedback
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12423
                      #210
                      ST - 240JP73
                      XPS 13 9310
                      Service Tag: 240JP73
                      • Uldix
                        • Nov 2025
                        • PT
                        #211
                        try and feedback
                        Thanks, LBTT1121, for a quick response.
                        Reading now 2 4 code for onboard RAM, seems like somebody has messed around with it already. Interestingly CPU is also getting very hot quickly. Any tips on identifying the faulty RAM chip?
                        • Uldix
                          • Nov 2025
                          • PT
                          #212
                          Originally posted by hoaca388
                          XPS 13 9310
                          Hi hoaca388! I tried your version as well, and there was no sign of life whatsoever.
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • mikeybass
                            by mikeybass
                            04-23-2025, 04:30 PM
                          • capoplays
                            Help with BIOS update on Dell G15 5515 after chip replacement
                            by capoplays
                            Hey everyone,
                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                            When I check the BIOS using the F12 menu Flash...
                            10-24-2025, 06:53 AM
                          • Akhlz001
                            by Akhlz001
                            09-20-2025, 07:15 PM
                          • Sathsul
                            Dell Latitude 5431 issues with dumping bios
                            by Sathsul
                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                            10-28-2025, 07:49 AM
