Dell XPS 9310 GDA30 LA-J143P bios repair please
  • Lovro25
    • Jan 2023
    • 11
    • Croatia
    #181
    Can someone fix this bios. Laptop turns on and only shows Dell logo.
    ST: FKH7793
    • richardsmr
      • Aug 2021
      • 25
      • england
      #182
      hi can someone help please fix bios stuck on logo
      dell xps p103g
      s/n 65vw2f3
      • hoaca388
        Badcaps
        • Jan 2022
        • 11874
        #183
        dell xps p103g
        s/n 65vw2f3
        XPS 13 9310 2-in-1
        Service Tag: 65VW2F3
        • hoaca388
          Badcaps
          • Jan 2022
          • 11874
          #184
          ST: FKH7793
          Why do you have to lie like that ?
          XPS 13 9310
          Service Tag: FKH7793
          • richardsmr
            • Aug 2021
            • 25
            • england
            #185
            Originally posted by hoaca388
            XPS 13 9310 2-in-1
            thankyou but still have same fault turns on stuck on dell logo and caps lock stays lit
            • alihomee
              • Dec 2012
              • 1577
              • malaysia
              #186
              dell xps 13 9310 service tag is:3P2G7D3 ...tried some files from this thread but no luck it hangs on dell logo and with some other files it restarts 3 times and then a dim display with dell logo anf fan full speed i attached orignal file ...motherboard code is :GDa30 LA-J143p
              • lapfix
                • Mar 2020
                • 2741
                • my workshop
                #187
                Try this clean me of your bios
                Bios version : 3.30.0
                Me version : 15.0.50.2633
                • alihomee
                  • Dec 2012
                  • 1577
                  • malaysia
                  #188
                  thanks for responce...tried this file after first restarts screen is blank with 8 white and 2 orange blinks......now orignal condition changed no more hang but after restarts no display and fans are loud
                  • lapfix
                    • Mar 2020
                    • 2741
                    • my workshop
                    #189
                    Try :
                    The blinking pattern you’re observing (2 amber, 8 white) points to an LCD failure. Here are some steps to consider:
                      • Check the Screen: Even if the screen appears to be working fine, there might be underlying issues with the LCD panel itself. Sometimes, subtle problems can cause this error code.
                      • Reseat the LCD Cable: Open up your laptop (if you’re comfortable doing so) and reseat the LCD cable. Sometimes, loose connections can trigger false error codes.
                      • Hold the Power Button: Try holding down the power button for about 30 seconds while the laptop is in Windows. This action can sometimes reset certain components and resolve the issue.
                      • CMOS Battery: If the problem persists, check the CMOS battery. A dead CMOS battery can sometimes cause unexpected errors. If you need to replace it, ensure you have your Bitlocker key handy if you’re using Bitlocker authentication.
                      • Motherboard: If none of the above steps work, it’s possible that the issue lies with the motherboard. You might need to consider replacing it.
                    • Bios White
                      Learn
                      • Dec 2024
                      • 72
                      • East Laos
                      #190
                      The device does not receive wifi, has replaced another wifi, please build Bios XPS 13 9310
                      TAG : GDN4DB3
                      • Bios White
                        Learn
                        • Dec 2024
                        • 72
                        • East Laos
                        #191
                        Someone help me
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11874
                          #192
                          TAG : GDN4DB3
                          XPS 13 9310
                          Service Tag: GDN4DB3
                          • Bios White
                            Learn
                            • Dec 2024
                            • 72
                            • East Laos
                            #193
                            XPS 13 9310
                            thank you,
                            Dell logo hanging machine
                            please help me
                            • PHÚC
                              • Oct 2017
                              • 14
                              • VIỆT NAM
                              #194
                              Hi guys, i m stucked with this xps 9310 , stucked on dell logo
                              here is the original dump, thank you in advance for your help
                              Dell XPS 13 9310
                              Service Tag : FG0Z693
                              EX: 33620834919
                              Model : P117G
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11874
                                #195
                                Dell XPS 13 9310
                                EX: 33620834919
                                Model : P117G
                                XPS 13 9310
                                Service Tag: FG0Z693
                                • PHÚC
                                  • Oct 2017
                                  • 14
                                  • VIỆT NAM
                                  #196
                                  XPS 13 9310
                                  cám mơn bạn mình sẻ thử và báo cáo lại
                                  Thanks, I will try and report back.
                                  KÍCH NGUỒN HIỆN LOGO TẦM 2S LÀ TẮT BẠN CÁM MƠN SỰ GIÚP ĐỠ CỦA BẠN
                                  START THE POWER LOGO SHOW FOR ABOUT 2S AND THEN IT TURN OFF. THANK YOU FOR YOUR HELP.
                                  in English please...
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • mikeybass
                                    by mikeybass
                                    04-23-2025, 04:30 PM
                                  • jhanra
                                    by jhanra
                                    11-02-2024, 04:19 AM
                                  • gizaha
                                    by gizaha
                                    02-13-2024, 07:18 AM
                                  • mrrubik
                                    Dell Optiplex 7010 micro bad BIOS flash?
                                    by mrrubik
                                    Hi folks,
                                    I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                    After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                    Steps I took:
                                    1. Read BIOS with CH341a, verified hash twice
                                    2. Patched
                                    12-23-2024, 04:11 PM
