Dell Microsoft autopilot issue
  • volinakis
    • Jan 2021
    • 2790
    • N/A
    #41
    Originally posted by Udemzy
    Hello, pls what do you mean by invalidate it?
    change AA553F to AA553C above Autopilot, see post 33
    • Udemzy
      • May 2017
      • 162
      • Guatemala
      #42
      I did exactly that and laptop refuse to power on after returning back the file, I had return back the back up file.
      I select the windows key and auto fill with 00 via hex editor and change the (?) to (<)
      Save and reprogram, laptop did not turn on.
      Change only the AA553F to AA553C alone, without touching the windows key.
      Same thing, I'll post the backup file, maybe you can help me with it.
      • volinakis
        • Jan 2021
        • 2790
        • N/A
        #43
        from where did you understand that you have to change "windows key"? Read again posts, maybe you'll realise what you are doing wrong.
        • Udemzy
          • May 2017
          • 162
          • Guatemala
          #44
          Noted, thank you.
          • Udemzy
            • May 2017
            • 162
            • Guatemala
            #45
            Please which app do you in opening the file?
            I'm using hex editor but I can't see the auto pilot.
            • Udemzy
              • May 2017
              • 162
              • Guatemala
              #46
              Hello, pls can you help me remove the auto pilot in this file.
              ​​​​​I tried using the method in post #33 but I didn't get it.
              • volinakis
                • Jan 2021
                • 2790
                • N/A
                #47
                follow rules of this forum and post laptop model and serial. I am using an hex editor for mac, is similar with HxD, AUTO_PILOT is there in your bios dump ... Click image for larger version
Name:	Screen Shot 2025-01-23 at 05.14.33.png
                • Udemzy
                  • May 2017
                  • 162
                  • Guatemala
                  #48
                  Thank you for your time and patient, I had to change the text string to unicode before I can locate it.
                  • volinakis
                    • Jan 2021
                    • 2790
                    • N/A
                    #49
                    and yet you didn't follow the rules of this forum ... next time I won't help you.
                    • Udemzy
                      • May 2017
                      • 162
                      • Guatemala
                      #50
                      Sorry about that,I moved the file to my phone and uploaded here when I got home, I wasn't with the laptop when i made the post.
                      When I got to the office the next day I was able to figure it out, that's why I didn't post it again.
                      • Mekong500
                        • Oct 2024
                        • 22
                        • Poland
                        #51
                        Hello everyone, can someone have a look at my file? I want to remove autopilot but there is no AA553F or AA553C near autopilor_marker in the file. Any advice how to remove it? Thanks in advance. Dell optiplex 7070
                        • volinakis
                          • Jan 2021
                          • 2790
                          • N/A
                          #52
                          There isn't because it's another bios platform (AMI) and invalidation is made in another way.
                          Here's your file.
                          • Mekong500
                            • Oct 2024
                            • 22
                            • Poland
                            #53
                            Thank you very much, I'll try it in the morning. I see the differences between the files, but could you share your knowledge how it works? Is it gonna be the same with other of that model? I've got more of them and I don't wanna waste people's time and ask for help if I could do it o my own. Thanks
                            • volinakis
                              • Jan 2021
                              • 2790
                              • N/A
                              #54
                              I explained how it works in this thread. It's simple to open bios with UEFITool and see how it can be invalidated an entry, depends by bios platform.
                              Click image for larger version  Name:	Screen Shot 2025-02-06 at 21.41.40.png Views:	0 Size:	104.9 KB ID:	3565962
                              Click image for larger version  Name:	Screen Shot 2025-02-06 at 21.39.11.png Views:	3 Size:	130.8 KB ID:	3565960
                              • Mekong500
                                • Oct 2024
                                • 22
                                • Poland
                                #55
                                Thanks for the answer. I think you showed me the right path to do it. I just tried to change the value with HxD and check with UEFITool and it's invalid even if it's 7878 instead of 8343, so just last question, can I change it to any value and it's gonna work or it has to be 0303 like you did it? Sorry for many questions but I'm just trying to understand it
                                • volinakis
                                  • Jan 2021
                                  • 2790
                                  • N/A
                                  #56
                                  you might think there is a reason I invalidated in that way, yet you want to complicate things ... put any value you want and see what happens, good luck!
                                  • Mekong500
                                    • Oct 2024
                                    • 22
                                    • Poland
                                    #57
                                    I also might think that e.g. you were born on 3rd march and 0303 are your favourite numbers. Instead of giving simple answer you want to complicate things and write ambiguous phrases​. I appriciate your help, but if you don't want to treat people without condescension just don't answer my questions. I tried to be nice in my posts. PS I tried two versions 7878/0303 and both work the same - autopilot is still on after fresh install
                                    • volinakis
                                      • Jan 2021
                                      • 2790
                                      • N/A
                                      #58
                                      I also might think that e.g. you were born on 3rd march and 0303 are your favourite numbers. Instead of giving simple answer you want to complicate things and write ambiguous phrases. I appriciate your help, but if you don't want to treat people without condescension just don't answer my questions. I tried to be nice in my posts. PS I tried two versions 7878/0303 and both work the same - autopilot is still on after fresh install
                                      lol, thank you for trying to be nice when you ask for help! Even with photos you didn't understand what to do! Try your lotto favourite numbers but I assure you it won't work ...
                                      Bottom line, my modified bios worked, yours didn't, so try to find Waldo in pics I sent you
                                      • Mekong500
                                        • Oct 2024
                                        • 22
                                        • Poland
                                        #59
                                        Trying to be nice in every post, not only when I ask for help. I understood what to do from photos ("I see the differences between the files, but could you share your knowledge how it works?") but not why exactly that way. Did you read my previous post? I tired both files, yours and mine and none of them unlocked the pc
                                        • volinakis
                                          • Jan 2021
                                          • 2790
                                          • N/A
                                          #60
                                          and what AUTOPILOT has to do with "unlock" the PC? Microsoft Autopilot enroll pc into a company and when you install a new OS it won't allow you to set an account offline.
                                          • SuperJames
                                            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                            by SuperJames
                                            This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                            Specs
                                            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                            Backstory
                                            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                            10-23-2023, 04:09 PM
                                          • hazem3636
                                            need Bios Bin file Dell server 220
                                            by hazem3636
                                            hi everyone
                                            i need dump file for dell server r220
                                            i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                            i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                            if anyone has this method please need his supporting .
                                            all the best
                                            EXE file is attched and Original Bin file from the Bios Chip is attached also
                                            and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                            11-05-2022, 06:20 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Ven
                                            Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                            by Ven
                                            Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                            Issue Description:
                                            1. CPU Overheating to 100°C
                                              • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                              • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                              • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                              • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                              • Thermal
                                            02-12-2025, 03:57 PM
                                          • NotEnough
                                            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                            by NotEnough
                                            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                            What I've Tried So Far:
                                            • Reseated the cables.
                                            • Reinstalled AWCC and AlienFX services.
                                            • Attempted BIOS downgrade but no improvement.
                                            • Inspected ribbon cables for damage.
                                            • Explored the possibility of BIOS or
                                            10-19-2024, 01:34 AM
