Bios For ThinkPad L13 Gen 2
https://www.badcaps.net/donate -
https://www.badcaps.net/donateComment
did u solve the problem ?Comment
Lenovo Thinkpad L13 Gen 2 - Serial Number: PW-01A0XZ, Type Number: 21AB-003LUS
Rails checked ok and Fan working CPU, RAM warming but no display. If do CMOS Caps Lock, F1, F4 light showing until turn off. Next boot try no lights. That EC and BIOS gone?Attached Filesif you find these attachements useful please consider making a small donation to the site
I'm looking for the original BIOS dumps for a Lenovo ThinkPad L13 Gen 2 i5.
Machine details:
- Serial Number (SN): R9-1092XF
- Type Number (TN): 20VH-001NMX
This motherboard has two BIOS chips. I have the first one (BIOS1), but the second chip (BIOS2) is physically missing from the board and I believe I will need to order and program it myself.
Details:
- BIOS1 chip: MX25L25673GM2I-08G
- BIOS2 chip: missing
Any help with the original dumps (BIN files) for both chips would be greatly appreciated.
Thank you in advance!
Only units with vPro CPUs are supposed to have 2 chips (i5-1145G7 and i7-1185G7), the rest of them only have one. Open the schematics and you will see. Or check images on Lenovo's parts catalogue.Comment
There is an app called Lenovo PC Diagnostics. It can decode the beep melody into an actual fault code. So I'd start from there.
And here is the picture of your board from Lenovo (FRU: 5B21K85606)
As you can see, there was no second chip. I believe there has to be some design flaw with L13G2, cause you can see dozens of them dead on eBay. Maybe it is a soldered ram that needs a reflow, maybe something else. I have no idea. In any case, there is more than enough working bios dumps for a board like yours on this forum. Give them a try. Even without cleaning ME region, the board should start. It is gonna post with a significant delay, but nonetheless, a donor BIOS should work if the hardware is functional.
You can use this link https://pcsupport.lenovo.com/us/en/warranty-lookup#/ to verify that you're picking the right donor. Type in the serial, go to Parts - As-Built and filter by Logic boards. There were at least a few of them with i5-1135G7, and i7-1165G7 should also work.
Also, just in case if you're not sure whether your screen is in good shape or not, you can try the built-in LCD test. With a charger connected, press Fn+CTRL+power. Damaged/dead screen or cable may result in it playing a tune. Or you can try hooking it up to an HDMI screen with the LCD cable detached from the board.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you very much for your efforts. I will try your suggestions and download the new BIOS from here. I will write at the end what the problem was.Comment
L13 Gen 2 type 20VJ
pw00et7x
no display
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello everyone. I am repairing a Lenovo L13 gen 2 20vj, the motherboard is blinking with LEDs and does not turn on. Board version LAR-2 MB 19837-1, serial number PW-00R5FH. Help solve the problem with the BIOS. I tried to assemble a new bios through Intel FIT but my Bios is badly damaged. I am attaching a photo of the board and the old bios.Attached Filesif you find these attachements useful please consider making a small donation to the site
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
L13 Gen 2 Laptops (ThinkPad) - Type 20VJ
Serial PW-01EYX1
PLS clean ME!, Laptop wlan card not working, try another wifi card, not help my problem.
THXAttached Filesif you find these attachements useful please consider making a small donation to the site
SMDFlea laptop serial number, full name and model, motherboard model is already in my messege. I clean efs, try clean me but motherboard not starting with bios(clean me "configured"), also i tried replacing the "bios" zone + clean ME but the board still doesn't boot. Many bios dumps that I found on the internet have a different version of ME (I have corporate lp) but the board boots up and shows the splash screen. I just started learning how to work with fit 15\16, so I don't really understand how to properly restore the bios.Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
Hi
Device: Laptop
brand : Lenovo
Model: Lenovo ThinkPad p1
MB: LPM-1 MB 17870-2
SN: R9-0SP0WN
Request: I could get one good read of the bios chip in not writable any more
I can not open the bios file in FIT tool looking for someone to fix the bios or
give me a new dump this file is 32MB
Thank you...-
by MaxonDomkratHi everyone.
I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...-
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM - Loading...
