Bios For ThinkPad L13 Gen 2
  • hoaca388
    Badcaps
    • Jan 2022
    • 11640
    #81
    Originally posted by nabilgo
    i found 2 chip 32 mo i did read both of them
    L13 Yoga Gen 2 Laptops (ThinkPad) - Type 20VL
    • nabilgo
      • May 2016
      • 300
      • L.A
      #82
      bro theres two chip with 32 mo which one ?
      • hoaca388
        Badcaps
        • Jan 2022
        • 11640
        #83
        Just try the file I gave you.
        • nabilgo
          • May 2016
          • 300
          • L.A
          #84
          bro i told which chip i put theres two bios 32 mo ?
          • nabilgo
            • May 2016
            • 300
            • L.A
            #85
            which one i should flash
            • nabilgo
              • May 2016
              • 300
              • L.A
              #86
              Originally posted by memoslar
              Hi, serial number is R91096SS.
              The old bin is 32mb. I find some files there but not this size.
              I programmed but i have 3 blinks on led.
              I tested also an older bios but nothing. Something happened with Intel Management Engine Firmware? Is there any incompatibility?
              did u solve the problem ?
              • hoaca388
                Badcaps
                • Jan 2022
                • 11640
                #87
                Bios 1.
                • nabilgo
                  • May 2016
                  • 300
                  • L.A
                  #88
                  Bios 1.
                  when i flash it with ur bios no power and cpu makes noise but when i did flasht it on bios 2 the laptop start but the probleme still the same ??
                  • 3pka
                    • Aug 2024
                    • 16
                    • Mongolia
                    #89
                    Lenovo Thinkpad L13 Gen 2 - Serial Number: PW-01A0XZ, Type Number: 21AB-003LUS
                    Rails checked ok and Fan working CPU, RAM warming but no display. If do CMOS Caps Lock, F1, F4 light showing until turn off. Next boot try no lights. That EC and BIOS gone?
                    • PMDev
                      • Oct 2023
                      • 17
                      I'm looking for the original BIOS dumps for a Lenovo ThinkPad L13 Gen 2 i5.
                      Machine details:
                      - Serial Number (SN): R9-1092XF
                      - Type Number (TN): 20VH-001NMX
                      This motherboard has two BIOS chips. I have the first one (BIOS1), but the second chip (BIOS2) is physically missing from the board and I believe I will need to order and program it myself.
                      Details:
                      - BIOS1 chip: MX25L25673GM2I-08G
                      - BIOS2 chip: missing
                      Any help with the original dumps (BIN files) for both chips would be greatly appreciated.
                      Thank you in advance!
                      Click image for larger version  Name:	fe47d915-f606-4dad-97e3-26964a95828b.jpg Views:	0 Size:	391.0 KB ID:	3628768
                        SMDFlea commented
                        Editing a comment
                        Thread merged with existing topic.
                    • Zalman
                      • May 2020
                      • 32
                      • UA
                      #91
                      Details:
                      Only units with vPro CPUs are supposed to have 2 chips (i5-1145G7 and i7-1185G7), the rest of them only have one. Open the schematics and you will see. Or check images on Lenovo's parts catalogue.
                      • PMDev
                        • Oct 2023
                        • 17
                        Ok so I will send you a Picture of the motherboard.
                        Click image for larger version  Name:	b401561b-363d-4a0e-8b75-c35040c6459d.jpg Views:	0 Size:	489.9 KB ID:	3628998
                        I will check the schematic when I will find it also. Thank you for sharing this info! I got a problem because when I turned it on there is only a beep melody on the beginning and laptopt turn off. So that why I was thinking about the second chip.
                        • Zalman
                          • May 2020
                          • 32
                          • UA
                          #93
                          There is an app called Lenovo PC Diagnostics. It can decode the beep melody into an actual fault code. So I'd start from there.
                          And here is the picture of your board from Lenovo (FRU: 5B21K85606)
                          As you can see, there was no second chip. I believe there has to be some design flaw with L13G2, cause you can see dozens of them dead on eBay. Maybe it is a soldered ram that needs a reflow, maybe something else. I have no idea. In any case, there is more than enough working bios dumps for a board like yours on this forum. Give them a try. Even without cleaning ME region, the board should start. It is gonna post with a significant delay, but nonetheless, a donor BIOS should work if the hardware is functional.
                          You can use this link https://pcsupport.lenovo.com/us/en/warranty-lookup#/ to verify that you're picking the right donor. Type in the serial, go to Parts - As-Built and filter by Logic boards. There were at least a few of them with i5-1135G7, and i7-1165G7 should also work.
                          Also, just in case if you're not sure whether your screen is in good shape or not, you can try the built-in LCD test. With a charger connected, press Fn+CTRL+power. Damaged/dead screen or cable may result in it playing a tune. Or you can try hooking it up to an HDMI screen with the LCD cable detached from the board.
                          • PMDev
                            • Oct 2023
                            • 17
                            Thank you very much for your efforts. I will try your suggestions and download the new BIOS from here. I will write at the end what the problem was.​
                            • Laptop fix
                              • May 2025
                              • 4
                              • Dubai
                              #95
                              L13 Gen 2 type 20VJ
                              pw00et7x
                              no display
                              • shiyab
                                • Sep 2023
                                • 1322
                                • india
                                #96
                                Originally posted by Laptop fix
                                L13 Gen 2 type 20VJ
                                pw00et7x
                                no display
                                hi try
                                • Laptop fix
                                  • May 2025
                                  • 4
                                  • Dubai
                                  #97
                                  Originally posted by shiyab
                                  hi try
                                  Only 3 blinks and no power on
                                  • xander007
                                    • Jan 2017
                                    • 13
                                    • Украина
                                    #98
                                    Hello everyone. I am repairing a Lenovo L13 gen 2 20vj, the motherboard is blinking with LEDs and does not turn on. Board version LAR-2 MB 19837-1, serial number PW-00R5FH. Help solve the problem with the BIOS. I tried to assemble a new bios through Intel FIT but my Bios is badly damaged. I am attaching a photo of the board and the old bios.
                                  • hollo13
                                    • Mar 2017
                                    • 21
                                    • Hungary
                                    #99
                                    L13 Gen 2 Laptops (ThinkPad) - Type 20VJ
                                    Serial PW-01EYX1
                                    PLS clean ME!, Laptop wlan card not working, try another wifi card, not help my problem.
                                    THX
                                    • xander007
                                      • Jan 2017
                                      • 13
                                      • Украина
                                      #100
                                      SMDFlea​ laptop serial number, full name and model, motherboard model is already in my messege. I clean efs, try clean me but motherboard not starting with bios(clean me "configured"), also i tried replacing the "bios" zone + clean ME but the board still doesn't boot. Many bios dumps that I found on the internet have a different version of ME (I have corporate lp) but the board boots up and shows the splash screen. I just started learning how to work with fit 15\16, so I don't really understand how to properly restore the bios.
                                      • Marco_compucell
                                        Lenovo ThinkPad P1 LPM-1 MB 17870-2 32mb bios
                                        by Marco_compucell
                                        Hi
                                        Device: Laptop
                                        brand : Lenovo
                                        Model: Lenovo ThinkPad p1
                                        MB: LPM-1 MB 17870-2
                                        SN: R9-0SP0WN
                                        Request: I could get one good read of the bios chip in not writable any more
                                        I can not open the bios file in FIT tool looking for someone to fix the bios or
                                        give me a new dump this file is 32MB
                                        Thank you...
                                        07-05-2025, 12:09 PM
                                      • 1g0r
                                        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                        by 1g0r
                                        First, the data in brief:
                                        Manufacturer: Lenovo
                                        Model: ThinkPad L15 G3 21C3-0016GE
                                        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                        IC Bios 1: MX77L25650F
                                        IC Bios 2​: MX25L25673G
                                        EC Chip: NPCX997KAABX
                                        So far I've been a silent reader, but now I need your help
                                        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                        01-18-2025, 02:39 AM
                                      • RMDUiFT
                                        Should I buy a Lenovo Thinkpad E495 with bios password?
                                        by RMDUiFT
                                        Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                        I have a few questions:
                                        • If I would buy this laptop and have
                                        08-25-2024, 09:00 AM
                                      • Loki_Fido
                                        Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                                        by Loki_Fido
                                        Hi everyone, hope everyone's having a great day.
                                        I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                                        I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                                        So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                                        Does this mean the BIOS is fine? making it a hardware issue?
                                        I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                                        03-14-2025, 07:42 PM
                                      • helpmepleasethanks
                                        Thinkpad T440P bios repair after WIFI whitelist mod
                                        by helpmepleasethanks
                                        As per the the rules, here are the specifications of my laptop :
                                        • Make and model number : Thinkpad T440P
                                        • Serial number (S/N) : PB-03A7V7
                                        • Model type - Model (MTM) : 20AW-S2N800
                                        • Bios version : 2.50 (not 100% sure, that's what I remember)
                                        Here is the problem, and the events leading to it :
                                        1. Upgrade screen, keyboard, trackpad, RAM and CPU
                                        2. Reboot and use the laptop for a bit : everything is working fine
                                        3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
                                        4. Boot up the device : bios warning, as expected
                                        5. Shutdown the device again (no power)
                                        6. Connect the 8-pin clip of a CH341a
                                        01-09-2025, 12:09 PM
