Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
  • 1g0r
    1g0r
    • Jan 2025
    • 14
    • Deutschland
    First, the data in brief:
    Manufacturer: Lenovo
    Model: ThinkPad L15 G3 21C3-0016GE
    motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
    IC Bios 1: MX77L25650F
    IC Bios 2​: MX25L25673G
    EC Chip: NPCX997KAABX
    So far I've been a silent reader, but now I need your help
    I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
    I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...en-3-need-bios
    Laptop arrived and i ​t then turned out that the laptop also has a supervisor password.
    Okay, one thing at a time, first remove the bios password.​
    I started to desolder the bios chip and a pad tore off, see pictures. Unfortunately, I was no longer able to understand whether there was one or two connections on the pad.
    Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: 001.jpg Ansichten: 0 Gr??e: 2,97 MB ID: 3551334
    After a long examination, I was of the opinion that there were two connections - I think it was a mistake.
    Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: 003.jpg Ansichten: 0 Gr??e: 5,27 MB ID: 3551335 Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: 005.jpg Ansichten: 4 Gr??e: 5,29 MB ID: 3551336
    In my opinion now, connection 2 and conductor track B are the only connection.
    However, I connected both and tried my luck - unfortunately without success.​
    Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: 023.jpg Ansichten: 0 Gr??e: 3,21 MB ID: 3551333 Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: 024.jpg Ansichten: 4 Gr??e: 3,05 MB ID: 3551332
    Unfortunately there isn't one here yet circuit diagram, but could someone send me a picture of their mainboard showing what the original connection looks like?
    Could someone tell me which component my additional connection may have caused damage to - i.e. not towards the BIOS chip but the other direction.
    I'll remove and check the bios chip on Monday when the children are not home - with a bit of luck I'll only have shot the bios chip.​
    The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1224
    • France
    Click image for larger version  Name:	image.png Views:	0 Size:	1.31 MB ID:	3551460
    only this one, I think.
    use dot repairing or smaller wire on the dot and wrap it like a snail to recreate a pad.
    Click image for larger version  Name:	51Zms7q0+QS._AC_.jpg Views:	0 Size:	41.6 KB ID:	3551461
    Ch341 consider the number of topics there are here for reading problems,
    you will understand that it is not reliable.
    For the bios password, you won't do it with reading the bios.
    NCPX997 it's in the ec.
    autopatcher will not work​
    • FriedFred
      • May 2024
      • 137
      If you are not shure about a recreation connection, better use a resistor like 1kOhm in between the wiring. In case of a wrong connection, you will not damage a signal / IC.
      • MaxonDomkrat
        Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
        by MaxonDomkrat
        Hi everyone.
        I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
        07-30-2025, 01:27 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • RMDUiFT
        Should I buy a Lenovo Thinkpad E495 with bios password?
        by RMDUiFT
        Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
        I have a few questions:
        • If I would buy this laptop and have
        08-25-2024, 09:00 AM
      • Loki_Fido
        Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
        by Loki_Fido
        Hi everyone, hope everyone's having a great day.
        I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
        I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
        So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
        Does this mean the BIOS is fine? making it a hardware issue?
        I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
        03-14-2025, 07:42 PM
      • helpmepleasethanks
        Thinkpad T440P bios repair after WIFI whitelist mod
        by helpmepleasethanks
        As per the the rules, here are the specifications of my laptop :
        • Make and model number : Thinkpad T440P
        • Serial number (S/N) : PB-03A7V7
        • Model type - Model (MTM) : 20AW-S2N800
        • Bios version : 2.50 (not 100% sure, that's what I remember)
        Here is the problem, and the events leading to it :
        1. Upgrade screen, keyboard, trackpad, RAM and CPU
        2. Reboot and use the laptop for a bit : everything is working fine
        3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
        4. Boot up the device : bios warning, as expected
        5. Shutdown the device again (no power)
        6. Connect the 8-pin clip of a CH341a
        01-09-2025, 12:09 PM
