Dell Latitude 5400 bios request
  • volinakis
    • Jan 2021
    • 2874
    • N/A
    #41
    Originally posted by gotigroj
    thank you so much!
    To make technical questions can be done on this forum or it is only for requests ? I am comparing the modified file with the original one to see what to change and I see you changed only 4 bytes from AA to 00... Is this right? how you determine which bytes have to be modified ?
    Thank you!
    group bytes by 4 and you'll get it ...
    • gotigroj
      • Jun 2024
      • 7
      Thank you, I found out that will be in groups of 4 but... do i have always look for the same 4 patterns or depends on the laptop will be different? How you know which patterns are the ones that you have to modify? (I saw other 32MB dump on previous page and I saw that they had 3 of the same Byte groups that end in AA changed to 00, but there was one pattern that I did not have in my BIOS.. is there a list or documentation of all the possible variants that need to be modified ?)
      Thanks!
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        #43
        Thanks!
        come on, is too simple to miss it! You want informations on a plate instead working a little bit! Download more bioses and compare them against unlocked ones. Start by reading BIOS guides, methods, resources and tools of this forum.
        • gotigroj
          • Jun 2024
          • 7
          it might be simple if you worked with it before, but is my first time playing around with bios dumps and flashing... I could only see certain patterns and not sure if the patterns repeat with the type of chip or not.
          I did read the post but all the references to my model are towards a program that could patch it, it does not have any information or I could not find any information of why we choose those patterns and why we replace them like that. I am sure I can download other ones and replicate them, but my goal was learn, that's why I made the questions. Sorry if that bothered you.
          I have couple more laptops and will practice with those, thanks for the help.
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            #45
            really? Are you having troubles to understand what you read?
            • gotigroj
              • Jun 2024
              • 7
              I broke the chip of the BIOS that you modified when trying to solder it back,
              I have other Latitude 5400s and I could follow and replace the 00 FC AA and 00 FD AA Patterns, I have flashed the modified BIOS but the screen will keep black and booting constantly... I tried to press F1 during boot and also pressing F2 during the boot but the screen will not turn back on... There is no signs of POST or any screen output at all... I can only hear the fans going on and then the computer will power off by itself after 30 seconds.
              Does this mean that I did modified the bios in a wrong way or that the BIOS file got corrupted while flashing ? Or is there any other step that I am missing in between?
              EDIT: Forgot to mention that ignored when the 00FDAA patterns looked like this for example:
              7EB26400 FDAA3F82 . Is that right? Also, what would be the start and end of the 0xXXXXXXX to start and end modifying this patterns? I think that could be the main problem that I am facing.
              Thanks.
              • Rameez Ahmed
                • Apr 2023
                • 21
                • Dubai
                #47
                HELLO SIR
                DELL LATITUDE
                `5400
                SERVICE TAG :- 6H8C3X2
                MOTHERBOARD CODE :- EDC41 LA-G891P REV :1.0 (A00)
                NO DISPLAY
                PLEASE CHECK BIOS AND REPAIR
                THANK YOU IN ADVANCED
                • peste
                  • Dec 2016
                  • 13701
                  • ROMANIA
                  #48
                  Originally posted by Rameez Ahmed
                  HELLO SIR
                  5400
                  LA-G891P
                  NO DISPLAY
                  read the rules..https://www.badcaps.net/forum/troubl...before-posting
                  post the Service Tag..the full name and model of the laptop,
                  • aquif
                    • Sep 2014
                    • 56
                    • India
                    #49
                    DELL LATTITUDE 5400
                    SERVICE TAG-23BQ1X2
                    BOARD PART NUMBER- LA-G891P
                    BLANK DISPLAY PLEASE BUILD THE BIOS
                    THANKS
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      #50
                      Originally posted by aquif
                      DELL LATTITUDE 5400
                      SERVICE TAG-23BQ1X2
                      THANKS
                      try and test
                      • aquif
                        • Sep 2014
                        • 56
                        • India
                        #51
                        Originally posted by kalilinux25
                        try and test
                        THANKS ITS WORKING.....
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          #52
                          nice great to here it
                          • Kamlesh Soni
                            • Aug 2024
                            • 12
                            • INDIA
                            #53
                            Hell guys I'm having a trouble I have 5400 8fc8 locked I have tried many bios it's working but I lost the audio
                            serial : 5HB0N33
                            service tag 5HB0N33
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12368
                              #54
                              serial : 5HB0N33
                              service tag 5HB0N33
                              Unlocked.
                              ​https://www.badcaps.net/donate
                              • Al-Umar
                                • Jan 2024
                                • 34
                                • Nigeria
                                #55
                                Help please, the Original bios file of this pc as bean removed.
                                The PC as been tooken to somewhere before so i need someone to get me the bios file those one i get from the site are not working fine with the pc, could someone matching one
                                Here is info:
                                EDC41 LA-G891P Rev:1.0(A00)
                                S/T: 2LHJL33
                                Dell Latitude 5400
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12368
                                #56
                                Here is info:
                                S/T: 2LHJL33
                                Dell Latitude 5400
                                Latitude 5400
                                • danielgagcia
                                  • Jul 2020
                                  • 33
                                  • Mexico
                                  #57
                                  Hello everyone!
                                  Could someone help to delete this bios password ?
                                  Dell 5400
                                  Service Tag : J8D7N53
                                  Mainboard : EDC41 LA-G891P Rev: 1.0 (A00)
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12368
                                    #58
                                    Originally posted by danielgagcia
                                    Hello everyone!
                                    Dell 5400
                                    Unlocked.
                                    • danielgagcia
                                      • Jul 2020
                                      • 33
                                      • Mexico
                                      #59
                                      Originally posted by hoaca388
                                      Unlocked.
                                      Thanks my guy works perfectly!
                                      • Alexsander Espindola
                                        • Sep 2024
                                        • brasil
                                        #60
                                        Hello everybody! Can anyone help to erase this bios password? I'm trying to do a Raid0 but I can't access it due to the password
                                        Here is the information:
                                        Dell 5400
                                        Serial: 5R94S63
                                        Service Tag: 5R94S63 *(8FC8)*
                                        Motherboard: EDC41 LA-G891P Rev: 1.0 (A00)
                                        Winbond 25Q256JV​
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                          11-02-2024, 04:19 AM
                                        • Godfather79
                                          Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                          by Godfather79
                                          Hello everyone in the community
                                          Dear Sir,
                                          I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                          Problem details:
                                          * Model: Dell Latitude 5520.
                                          * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                          * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                          * Service Tag: (Enter your actual Service Tag from the laptop here)
                                          * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                          Yesterday, 10:04 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                        • YOUCEF4787
                                          Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                          by YOUCEF4787
                                          I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                          Initial Problem:
                                          The laptop was completely dead, no signs of life, no power LED.
                                          Action Taken:
                                          I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                          Current Situation & The Main Issue:
                                          The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                          09-21-2025, 12:19 PM
