could you help me with this bios does not give an image does not turn the fan either
dell 3420 cyborg-L14 mb 203068-1 help me with this bios
Re: dell 3420 cyborg-L14 mb 203068-1 help me with this bios
Latitude 3420Attached Files↵
https://www.badcaps.net/donate -
This file from other laptopAttached Files↵
https://www.badcaps.net/donateComment
AgainAttached Files↵
I have Dell 3420 with lock,
someone can unlock this model?Attached FilesComment
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hello everyone, I need help unlocking this same bios . I tried a rom that was unlocked and replaced ME region using uefitool but the machine wont even turn on after replacing ME... thanks in advance..Attached FilesComment
Attached Files↵
Worked! Many thanks, is there any chance you can pointme in the right direction to learn how patch these files...?Comment
this file proved to me that the bios chip is fine , as i have dell 3420 cyborg-L14 mb 203068-1 which have mdm , i thought i can remove it by editing the bios, didnt work for me so i flashed back the backup file but the backup dump file is damaged( based on trying your file ), the laptop starting with sold colours then off, but with your file it boots , but i have problem , the laptop with your file not charging, what can i do in this case?Attached FilesComment
this file proved to me that the bios chip is fine , as i have dell 3420 cyborg-L14 mb 203068-1 which have mdm , i thought i can remove it by editing the bios, didnt work for me so i flashed back the backup file but the backup dump file is damaged( based on trying your file ), the laptop starting with sold colours then off, but with your file it boots , but i have problem , the laptop with your file not charging, what can i do in this case?Attached Files↵
thank you , with the previous file you uploaded the battery had 20% , the laptop did not detect the charger, didnt even worked bluged charger without battery, so if i disconnect the battery and use the charger only the laptop acts dead, laptop with battery connected is fine comes on and drainnig the battery obviously like normal laptop but without charging, the laptop gone dead as the battery flat now, now with your new file the laptop act the same , the battery is flat , so now the laptop not coming on at all, any suggestion pls? the laptop was charging before removing the chipComment
please removed bios passwordAttached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by sammus540I have a Vostro 3420 8H8K5R3-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
