Dell Vostro 3420 BIOS Password Removal
  • kimarth21
    • Jan 2020
    • 12
    • Philippines
    please help me unlock device freeze
    dell latitude 3420 device freeze 7332
    st: 726FXL3
      • 22030
      st: 726FXL3
      This thread is for the Vostro .Post your request in the latitude 3420 thread --> https://www.badcaps.net/forum/troubl...assword-unlock
      • spider300
        • Apr 2022
        • 35
        • morocoo
        Hello. Ive got problem with Dell Vostro 3420. After power on, no display . Standard job, I exported a clean bios from update via pfs extract.
        Steps i done and results:
        I exported a clean bios from update file via pfs extract.
        1. Build clean bios with clean ME, PMC, PCH in flash image tool.
        Result: Dead
        2. Build clean bios with no changes in ME, new PMC, PCH
        Result: Dead
        3. Build old bios with clean ME, new PMC, PCH
        Result: The same
        GDM51 LA-L242P Rev:1.0(A00) 2021-07-04
        ST:HJ5LB24
        In the attachment i give you original dump. I would be grateful for any tips on building batches in new generations - maybe I don't know something.
        • peste
          peste commented
          Editing a comment
          merged post..
      • OmanCloud
        • Aug 2023
        • 18
        • Oman
        Hi Brothers
        please Help me remove password
        Dell Inspiron 15- 3520
        LA-L946P-REV;1.0
        Service Tag : 8CLNVH3
        hoca peste
Name:	WhatsApp Image 2025-06-19 at 5.36.36 PM.jpg
        • lapfix
          • Mar 2020
          • 2765
          • my workshop
          Originally posted by OmanCloud
          Hi Brothers
          LA-L946P-REV;1.0
          hoca peste
          Click image for larger version  Name:	WhatsApp Image 2025-06-19 at 5.36.36 PM.jpg Views:	0 Size:	1.45 MB ID:	3664366
          1st boot, press F2, write service tag, disable Absolute, save, restart.
          2nd boot press Alt+F to exit manufacturing mode.
          Good luck.
          • OmanCloud
            • Aug 2023
            • 18
            • Oman
            #26
            Good luck.
            Caps lock Blinking no Display
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              #27
              I guess you try without cmos..the unlock file is OK..verify again
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • 417731
                BIOS needed for Dell Vostro 3405
                by 417731
                Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                Model: Dell Vostro 3405
                Tag:F0B1YF3
                CPU:Ryzen 3500U
                Thanks in advance
                07-06-2025, 06:48 PM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
