dell 3420 cyborg-L14 mb 203068-1 help me with this bios
  • jm801
    Banned
    • Apr 2020
    • 123
    • monterrey
    could you help me with this bios does not give an image does not turn the fan either
  • hoaca388
    Badcaps
    • Jan 2022
    • 11813
    Re: dell 3420 cyborg-L14 mb 203068-1 help me with this bios
    Latitude 3420
    • jm801
      Banned
      • Apr 2020
      • 123
      • monterrey
      Originally posted by hoaca388
      Latitude 3420
      it does not turn on with that programming
      • hoaca388
        Badcaps
        • Jan 2022
        • 11813
        This file from other laptop
        • jm801
          Banned
          • Apr 2020
          • 123
          • monterrey
          with that it turns on but without image and the fan very fast
          • hoaca388
            Badcaps
            • Jan 2022
            • 11813
            Again
            • jm801
              Banned
              • Apr 2020
              • 123
              • monterrey
              Again
              with that it does not turn on
              • niharkanti
                • Sep 2015
                • 15
                • india
                working this file , no image means check power led blinking ,
                • osman68i
                  • May 2015
                  • 338
                  • The Netherlands
                  I have Dell 3420 with lock,
                  someone can unlock this model?
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • osman68i
                      • May 2015
                      • 338
                      • The Netherlands
                      thanks vesko
                      its working great
                      • tarcisoamaralfilho
                        Noteweb
                        • 10
                        • Brazil
                        Hello everyone, I need help unlocking this same bios . I tried a rom that was unlocked and replaced ME region using uefitool but the machine wont even turn on after replacing ME... thanks in advance..
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11813
                          Here
                            Noteweb
                            • 10
                            • Brazil
                            Worked! Many thanks, is there any chance you can pointme in the right direction to learn how patch these files...?
                            • layad
                              • Nov 2011
                              • 244
                              this file proved to me that the bios chip is fine , as i have dell 3420 cyborg-L14 mb 203068-1 which have mdm , i thought i can remove it by editing the bios, didnt work for me so i flashed back the backup file but the backup dump file is damaged( based on trying your file ), the laptop starting with sold colours then off, but with your file it boots , but i have problem , the laptop with your file not charging, what can i do in this case?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11813
                                dell 3420 cyborg
                                • layad
                                  • Nov 2011
                                  • 244
                                  dell 3420 cyborg
                                  thank you , with the previous file you uploaded the battery had 20% , the laptop did not detect the charger, didnt even worked bluged charger without battery, so if i disconnect the battery and use the charger only the laptop acts dead, laptop with battery connected is fine comes on and drainnig the battery obviously like normal laptop but without charging, the laptop gone dead as the battery flat now, now with your new file the laptop act the same , the battery is flat , so now the laptop not coming on at all, any suggestion pls? the laptop was charging before removing the chip
                                  • layad
                                    • Nov 2011
                                    • 244
                                    dell 3420 cyborg
                                    sorted thank you
                                    • SNUSYED
                                      • Jan 2021
                                      • 11
                                      • India
                                      Thank 😊lot brother
                                      • jatoi
                                        • Jan 2015
                                        • 83
                                        • pakistan
                                        please removed bios password
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • sammus540
                                          Dell Vostro 3420 BIOS Password Removal
                                          by sammus540
                                          I have a Vostro 3420 8H8K5R3​-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
                                          And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.
                                          03-28-2024, 06:33 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
