ThinkBook 15 G2 ITL bios password
  • peste
    • Dec 2016
    • 13357
    • ROMANIA
    #81
    Originally posted by Kainith
    Hi, i´am new here, so sorry when i don´t know much . i need a Passwort for a ThinkBook 15 G2 ITL
    S/N: MP22HFAW
    MTM: 20VE00FNGE
    MO: MPNXB180908D Factory ID: PRC4
    If i must flash a Chip or so, let me know , i got a CH341A HERE
    thank you for helping .
    post the original contents of the bios chip..
    • Kainith
      • Sep 2025
      • 6
      • germany
      #82
      I hope it are the right files
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1316
        • France
        #83
        password
        • Kainith
          • Sep 2025
          • 6
          • germany
          #84
          thank you . but did i do something wrong ?the laptop wont start anymore. so i cant try the passwort
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1316
            • France
            #85
            Maybe because of CH341.
            The serial killer BIOS programmer.
            Did you unsolder or read with clip?
            Did you rewrite over it?
            Bad solder joints, torn resistors.
            It could be due to many things.
            • Kainith
              • Sep 2025
              • 6
              • germany
              #86
              did it with the clip and hadnt rewrite over i hope i dont kill it completly
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1316
                • France
                #87
                Black screen or no power
                Remove battery a few seconds and try again
                • Kainith
                  • Sep 2025
                  • 6
                  • germany
                  #88
                  The power button blinks and there is no screen or fan
                  • majster-pl
                    Majster
                    • Sep 2025
                    • 26
                    Originally posted by Jovica123
                    In the end, it turned out that the problem was not related to the BIOS at all, but to the motherboard itself.
                    When I first received the laptop for repair, I powered it on and saw that it was locked. I turned it off and began the unlocking process. However, after I first removed both chips, read their contents, and soldered them back onto the board, on the next power-on attempt the laptop would no longer display an image (power LED stays on for 5 seconds, off for 5 seconds).
                    This morning, out of curiosity, I decided to try again. I noticed that the CPU was heating up, so I thought everything was fine. However, on the second power-on – after connecting the display – the laptop again refused to start.
                    I decided to try one method: I placed the motherboard in the fridge for 15 minutes, then powered it on again. Amazingly, the laptop started, displayed an image, and I shut it down using the power button. When I tried to power it on again, it wouldn’t start.
                    Is there anything that can be done in this case?
                    I have exactly the same issue as you but I didn't try a fridge yet... 😀
                    I'm wondering if the on board memory chips are not loosing connection when soldering or desoldering a BIOS from the board... I think they are just on the other side of the board.
                    I'll give it a close look later on today but it's suspicious that it's not the first board is getting damaged because of removing BIOS chip process.
                    This is my original post and what I've tried.
                    https://www.badcaps.net/forum/troubl...-functionality
                    Please let me know if you managed to solve the issue.
                    • majster-pl
                      Majster
                      • Sep 2025
                      • 26
                      Jovica123 Try to re-flow your CPU. It works for me. Good luck.
                      https://www.youtube.com/watch?v=5vfeV0ad2wI
                      • Aditya11ttt
                        Adi
                        • Feb 2019
                        • 186
                        • India
                        #91
                        ThinkBook 14 G2
                        MP22ZB46
                        please help unlock
                        • volinakis
                          • Jan 2021
                          • 2872
                          • N/A
                          #92
                          try pass: mresbi0s543 [bi(ZERO)s]
                          if doesn't work write UC12
                          • m1ch43lzm
                            • Mar 2019
                            • 771
                            • Peru
                            #93
                            Aditya11ttt Try
                            Code:
                            mresbi0s54
