HP BIOS unlock tool
Well yes, when i try to enter BIOS it asks for fingerprint OR password, if i press Esc it asks me if i want to enter as Guest.
Also the RCunlocker confirms there's a password and that password is removed.
I upload screenshot and original bios it self.
Thank you in advance
S/N: 5CG43701QQComment
Attached FilesComment
Hello!
Finally this BIOS worked, thank you very much.
P.S: It would be wise to keep in mind that under certain circumstances both utilities fail to edit the locked BIOS. Unfortunately i don't know the exact circumstances but i'll keep the locked BIOS stored in case someone wants to run some research.
Thank you again!Last edited by Andreasbest; 04-07-2025, 08:34 AM.Comment
First check this site to see if your HP is supported for the great tool Mazzif has made.
http://mazzifsoftware.blogspot.com/p...os-unlock.html
If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
Just program the new file on your bios IC.
This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
Code:Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
Code:"C:\*location-of-exe*\HPUnlocker.exe" "%1"
If there are any issues, please do let me know so I can improve this tool.
All Elitebooks, Probooks and zbooks which are up to ninth generation which should be up to year 2018, like 840 G5, are supported. Newer models are not supported (yet atleast).
No Pavilions or other trash is supported
NEW multitool and unlocker added .
Unlocking
HP - ProBook, EliteBook, ZBook (including 32MB models)
Chromebooks from all various manufacturers
Apple - everything older than T2
More to come...
RCUnlocker https://www.badcaps.net/forum/showthread.php?t=98539
.Comment
anyone please helpme can open for this bios password unlock(
type :HP x360 11 G7 ee
s/n:5CG1191N28
please helpme sirr)) thanksss
hello everyone, i am new here and could you please tell me how can i install hp unlocker tool? after i try to install it says FATAL ERROR DETECTED FAILED TO EXECUTE SCRIPT HPUNLOCKERComment
Every donation made will go towards server fees and maintenance costs.Comment
post the contents of the bios chip even if it is corrupted..
Don't post pictures unless asked.
I am trying to remove the BIOS lock of an HP elitebook 840-G8.
I have all tool & software (CH341A, RCUnlocker, AS-Programmer) available and working.
Since I don't have a suitable soldering station, I try to avoid soldering out the bios chip.
With a Wson-chip adapter, I read out the correct bios chip W25Q128JV on the motherboard, which is tricky.
Nevertheless I managed till now to read out the bios chip 8 times. Unfortinally all bios binaries are different, because of the of different CRC32 on the AS-Programmer. That is not suppriesing me.
Curiously the Unlocker tool works for all the different binaries.
The question is how to find the correct binary? Maybe the security mechanism use only a small memory part of the bios chip and the rest of the memory doesn't matter.
Has somebody experience with the topic, respectively any suggestions?
BrComment
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
Please point me to tutorials for dumping BIOS and restoring or flashing the unlocked BIOS file received from BIOS request.Comment
<BIOSCONFIG Version="" Computername="BOD" Date="2025/06/17" Time="18:52:38" UTC="1">
SPM: Not Provisioned.
BEAM mode: Disabled.
<SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access denied" returnCode="6">
<OLDVALUE><![CDATA[Lock]]></OLDVALUE>
<NEWVALUE><![CDATA[Unlock]]></NEWVALUE>
</SETTING>
<ERROR msg="An operation failed" />
<ERROR msg="BCU return value" real="13" translated="13" />
</BIOSCONFIG>
SMDFlea I have tried to unlock mpm with that method serverally. shows this errorComment
Try to reset your bios backup to factory settings then reflash the bios, and at 1st boot press F10 and RESET BIOS to factory defaults https://www.badcaps.net/forum/troubl...y-bios-patcher
SMDFlea I do not have CH programmer yet for flashing. The backup I have is previous BIOS done by the official updater.
Will that work? I have read a about the patch you mentioned. Just want to know if you talking about programmer backup or the normal update backup.Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
