HP BIOS unlock tool
    • 22122
    Originally posted by Andreasbest
    Ok now i'm into a very weird situation.
    I backed up the bios from a 650 G1, i drag into this tool and RCUnlocker too, the result is that both the original dump and the patched (from both tools) are identical!
    I compare them with HxD
    How is this even possible? I feel super dumb right now.
    Are you sure it has a password
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      #1582
      Well yes, when i try to enter BIOS it asks for fingerprint OR password, if i press Esc it asks me if i want to enter as Guest.
      Also the RCunlocker confirms there's a password and that password is removed.
      I upload screenshot and original bios it self.
      Thank you in advance
      S/N: 5CG43701QQ
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        #1583
        Can someone please remove the password from the above bios manually?
        Thank you in advance.
        • danito
          • Jun 2016
          • 1154
          #1584
          try
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            #1585
            Originally posted by danito
            try
            Hello!
            Finally this BIOS worked, thank you very much.
            P.S: It would be wise to keep in mind that under certain circumstances both utilities fail to edit the locked BIOS. Unfortunately i don't know the exact circumstances but i'll keep the locked BIOS stored in case someone wants to run some research.
            Thank you again!
            • b4rdock
              • Jun 2017
              • 106
              • usa
              #1586
              SMDFlea sir ,here i can ask for help with my strange case password HP Zbook Firefly 14 G9 ?
              • alihomee
                • Dec 2012
                • 1596
                • malaysia
                #1587
                Originally posted by RethoricalCheese
                First check this site to see if your HP is supported for the great tool Mazzif has made.
                http://mazzifsoftware.blogspot.com/p...os-unlock.html
                If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
                For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
                When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
                Just program the new file on your bios IC.
                This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
                For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
                Code:
                Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
                Then modify that string adding
                Code:
                "C:\*location-of-exe*\HPUnlocker.exe" "%1"
                This way you just need to right click your locked file and select HPUnlocker.
                If there are any issues, please do let me know so I can improve this tool.
                All Elitebooks, Probooks and zbooks which are up to ninth generation which should be up to year 2018, like 840 G5, are supported. Newer models are not supported (yet atleast).
                No Pavilions or other trash is supported
                NEW multitool and unlocker added .
                Unlocking
                HP - ProBook, EliteBook, ZBook (including 32MB models)
                Chromebooks from all various manufacturers
                Apple - everything older than T2
                More to come...
                RCUnlocker https://www.badcaps.net/forum/showthread.php?t=98539
                i am looking to use this softwere with win 11 ...any update or suggations as win 10 is good for this softwere but win 11 id not working propely
                • qwerty4512
                  • Dec 2024
                  • 29
                  • US
                  #1588
                  anyone please helpme can open for this bios password unlock (
                  type :HP x360 11 G7 ee
                  s/n:5CG1191N28
                  please helpme sirr )) thanksss
                  • shiyab
                    • Sep 2023
                    • 1647
                    • india
                    #1589
                    s/n:5CG1191N28
                    hi try
                    • qwerty4512
                      • Dec 2024
                      • 29
                      • US
                      #1590
                      Originally posted by shiyab
                      hi try
                      after on display ,bios notice 'systemnaufacture' ,can't open bios blackscreen ? have another solution?
                      • Muditha Folini
                        • May 2025
                        • 32
                        • Schweiz
                        #1591
                        hello everyone, i am new here and could you please tell me how can i install hp unlocker tool? after i try to install it says FATAL ERROR DETECTED FAILED TO EXECUTE SCRIPT HPUNLOCKER
                        • peste
                          • 13759
                          • ROMANIA
                          #1592
                          you don't have to install the program...read post #1.
                          • GreenTeam
                            • Apr 2025
                            #1593
                            I've managed to do it but when I restart my laptop its still asking for a password when im go into f10.
                            Is there a video that shows how to do this from start to finish?
                            i'm sure I'm doing something wrong?
                            any help would be appricated.
                            • peste
                              • 13759
                              • ROMANIA
                              #1594
                              post S/N, full name and model, motherboard model, product number,etc.
                              post the contents of the bios chip even if it is corrupted..
                              Don't post pictures unless asked.
                              • erwer
                                • Feb 2025
                                • Swiss
                                #1595
                                I am trying to remove the BIOS lock of an HP elitebook 840-G8.
                                I have all tool & software (CH341A, RCUnlocker, AS-Programmer) available and working.
                                Since I don't have a suitable soldering station, I try to avoid soldering out the bios chip.
                                With a Wson-chip adapter, I read out the correct bios chip W25Q128JV on the motherboard, which is tricky.
                                Nevertheless I managed till now to read out the bios chip 8 times. Unfortinally all bios binaries are different, because of the of different CRC32 on the AS-Programmer. That is not suppriesing me.
                                Curiously the Unlocker tool works for all the different binaries.
                                The question is how to find the correct binary? Maybe the security mechanism use only a small memory part of the bios chip and the rest of the memory doesn't matter.
                                Has somebody experience with the topic, respectively any suggestions?
                                Br
                                • peste
                                  • 13759
                                  • ROMANIA
                                  #1596
                                  The bios chip must be unsoldered from the board before writing or reading..
                                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                  solder wires between the programmer and the bios chip..
                                  • bod0007
                                    • Jun 2025
                                    • 10
                                    • Nigeria
                                    #1597
                                    Hi all, I have a HP EliteBook 855 G7 with 845 G7 BIOS details(i.e SN and Product number) I tried to correct it with BCD utilities but not work. I read I need to unlock MPM. Kindly help
                                    • bod0007
                                      • Jun 2025
                                      • 10
                                      • Nigeria
                                      #1598
                                      do I need to unlock BIOS to correct the DMI details.
                                      Please point me to tutorials for dumping BIOS and restoring or flashing the unlocked BIOS file received from BIOS request.​
                                        SMDFlea commented
                                        Editing a comment
                                        Use BCU 4.0 (Bios Config Utility) under cmd.
                                        biosconfigutility /get:1.txt and in 1.txt modify Manufacturing Programming Mode from *Lock to *Unlock (erase *from Lock and put it to Unock) save file as 2.txt and use biosconfigutility /set:2.txt then restart.
                                    • bod0007
                                      • Jun 2025
                                      • 10
                                      • Nigeria
                                      #1599
                                      <BIOSCONFIG Version="" Computername="BOD" Date="2025/06/17" Time="18:52:38" UTC="1">
                                      SPM: Not Provisioned.
                                      BEAM mode: Disabled.
                                      <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access denied" returnCode="6">
                                      <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
                                      <NEWVALUE><![CDATA[Unlock]]></NEWVALUE>
                                      </SETTING>
                                      <ERROR msg="An operation failed" />
                                      <ERROR msg="BCU return value" real="13" translated="13" />
                                      </BIOSCONFIG>​
                                      SMDFlea I have tried to unlock mpm with that method serverally. shows this error
                                    • bod0007
                                      • Jun 2025
                                      • 10
                                      • Nigeria
                                      #1600
                                      SMDFlea I do not have CH programmer yet for flashing. The backup I have is previous BIOS done by the official updater.
                                      Will that work? I have read a about the patch you mentioned. Just want to know if you talking about programmer backup or the normal update backup.
                                        SMDFlea commented
                                        Editing a comment
                                        programmer backup
                                    • salim5566
                                      loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                      by salim5566
                                      Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                      06-26-2025, 03:25 PM
                                    • to5it0
                                      by to5it0
                                      10-24-2025, 01:35 AM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      Hi everyone
                                      09-06-2025, 05:47 PM
