HP BIOS unlock tool
Re: HP BIOS unlock tool
hi who can help me unlock HP elitebook 840 G4 bios ?Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Here other bios binAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Tried the Mazzif software with HP Elitebook 830 G6 but password is still there. The chip I programmed is 256Mb but the bin file is 32Mb, is that where the password is stored or is it somewhere else. I see there may be a 16Mb file too but if that is the case I don't know which chip I need to program. Does anyone have a clean Bios dump and a picture of the 16Mb chip location please. I have attached the Mazzif unlocked file. Thank you.Attached FilesLast edited by SallyB; 03-26-2021, 10:53 AM.Comment
Tried the Mazzif software with HP Elitebook 830 G6 but password is still there. The chip I programmed is 256Mb but the bin file is 32Mb, is that where the password is stored or is it somewhere else. I see there may be a 16Mb file too but if that is the case I don't know which chip I need to program. Does anyone have a clean Bios dump and a picture of the 16Mb chip location please. I have attached the Mazzif unlocked file. Thank you.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thanks for the reply. I managed to locate the 128Mb chip on the other side of the motherboard. I have removed and tried the HPunlocker tool and replaced but still locked.
Looks like mazzif tool does not work on this one
I have attached both files, could someone please remove the password. Thanks.Comment
If you would have read a bit more, you would know that Mazzif tool works on very old laptops and the tool in first post works up to G5 with varying success.
I don't think my methods won't work on your laptop so I'll leave it up to pesteComment
I have attached both files, could someone please remove the password. Thanks.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
A neat tool that has helped me a few times.
I do wonder though. Would it be possible to get a Linux version of this tool? I just had to go through the process of installing windows just to use this one tool. I tried with wine but that would not work at all.
If you'd provide some code I might even be able to help to port it to linux.Comment
I actually always use it on linux myself (slightly modified to get it working there). Next month I can finally continue developing it. Will keep you in mind and share you the linux version.Comment
Have this kind of issue for my HP 820 G2 laptop, and I am not able to finish BIOS verification.
Software - CH341H ver. 1.34
Proggramer - CH341H
CHIP - W25Q128FV
Help, for now after erase I have black screen.
, after programming
first check this site to see if your hp is supported for the great tool mazzif has made.
http://mazzifsoftware.blogspot.com/p...os-unlock.html
if your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
For that you need an spi programmer like ch341a or raspberry pi with flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios ic.
When you have your dump, just drag and drop your file on my hpunlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
Just program the new file on your bios ic.
This unlocker should work on all elite, elitebook, probook and maybe some other series hp laptops.
For those of you who need to unlock large amounts of laptops, i recommend adding a registry entry:
Code:computer\hkey_classes_root\*\shell\hpunlocker\command
Code:"c:\*location-of-exe*\hpunlocker.exe" "%1"
If there are any issues, please do let me know so i can improve this tool.Comment
Try this bios file and reportComment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
