HP BIOS unlock tool
  • michelb07
    • Dec 2020
    • 7
    • france
    #601
    Re: HP BIOS unlock tool
    thk a lot for your answer Peste
    bios i sent are bios for 2 different laptops.
    they are both locked.
    so i have to unsolder the 2 16mb chips also ? that what you mean ?
    • peste
      • 13357
      • ROMANIA
      #602
      try..
      • michelb07
        • Dec 2020
        • 7
        • france
        #603
        Thanks so much !!
        That is mean that I don't have to watch for the other chip ? The 16mb.
        • peste
          • 13357
          • ROMANIA
          #604
          Thanks so much !!
          try it ... if it's not ok, we'll see ..
          • michelb07
            • Dec 2020
            • 7
            • france
            #605
            Oki
            I’ll give you a feedback
            • miguel.lourenco93
              • Dec 2020
              • Portugal
              #606
              top badass software, thank you so much :-)
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                #607
                Originally posted by Ghamidi
                i have elitebook 830 G6 when i refalsh EC i have this message in picture
                any help Mr RethoricalCheese
                thank you
                1 flash 16MB with a good one (no backup password inside)
                2 FLASH 32MB WITH CLEAN R70(extracted from bios update exe file) BIOS REGION using intel FIT ( you should get manufacturing programming mode at this step)
                3 FLASH ORIGINAL 32MB UNLOCKED by RethoricalCheese Unlocker
                done
                • matrim
                  • Dec 2020
                  • Portugal
                  #608
                  Hello everyone, and especially the professionals that are helping us here
                  Guys, my issue is pretty straightforward; I have a pass on my bios on my HP zbook 15 G3. I contacted HP to help me at the start of this year. Their help went as far as letting me buy a complete motherboard for a cheaper price. Cant afford it and they pissed me off like nothing before.
                  I was about to buy a bios chip from ebay to change mine but I like this solution much better. Will it work on my chip and will I need to solder or will the clip work directly?
                  • peste
                    • 13357
                    • ROMANIA
                    #609
                    it also works with the clip, but most of the time it gives errors, you have to make sure that the contact between the pins of the bios chip and the clip is as good as possible..it is best to remove the chip from the motherboard ..
                    https://www.youtube.com/watch?v=DWWigscuQDY
                    • R00ster
                      • Dec 2020
                      • Netherlands
                      #610
                      Originally posted by majubzer
                      Hello, I tried the tool for an HP 470 G5. I flashed with a CH341A into the chip (25B127DSIG I find no datasheet about it), but the Power-on Authentication still appears on log in.
                      Could you give a look to my original bios bin?
                      Thanks in advance
                      Hello majubzer, have you ever succeeded in disabling the Power-on Authentication? I'm having the same issue and not sure if the Unlock tool will help. Thanks for your rely.
                      • arie137
                        • Dec 2020
                        • usa
                        #611
                        I'm trying to unlock HP 820 g2 bios.
                        BIOS config file is attached.
                        Looking for some advice or next steps. Thanks...
                        • arie137
                          • Dec 2020
                          • usa
                          #612
                          Here's the BIOS config file for locked HP 820 g2.
                          • zmedia
                            • May 2018
                            • 63
                            • Algerie
                            #613
                            hi i have this dump for HP 735 g6 locked anywhere can unlocked thank u !!
                            • peste
                              • 13357
                              • ROMANIA
                              #614
                              try..
                              • zmedia
                                • May 2018
                                • 63
                                • Algerie
                                #615
                                its not working password always present
                                • peste
                                  • 13357
                                  • ROMANIA
                                  #616
                                  check on both sides of the board, if there is a bios chip and post the contents.
                                  • zmedia
                                    • May 2018
                                    • 63
                                    • Algerie
                                    #617
                                    yes this is contents bios chip
                                    • mrchippie
                                      • Dec 2020
                                      • Netherlands
                                      #618
                                      I just want to thank you for this awesome tool.
                                      I managed to remove the password of Probook 650 g1 after de soldering and re-flashing the BIOS chip.
                                      • Tomcsa
                                        • Jun 2020
                                        • 15
                                        • Hungary
                                        #619
                                        Hello Forum Members,
                                        can someone please check this dump? Laptop is HP 820 g3, with windbond 25q128fvpq wson8 chip, bios is password locked in this dump. (this dump is read by these: nero, asprogrammer, ch341, always verified, and contents always the same checked with hexeditor)
                                        Originaly the chip was desoldered to remove this bios password, but finally did nothing with chip..., then only soldered back to the laptop but it did not turn on anymore, only blinking power button and yellow/white leds keep lighting on front edge...
                                        Now winbond bios chip is out again, dump read, but this weekend a second attempt will come to build the laptop together, but first i would like to someone check if bios content maybe got corrupted or bad or something. We do not want to face again this problem that laptop not turning on if the problem is that the bios content is bad...
                                        If you say it is good bios and can write back to the bios chip, then maybe before that i finally will apply the 'HP unlocker tool' here to get rid of bios password.
                                        Thank you very much in advance.
                                        Regards,
                                        Tomcsa
                                        • peste
                                          • 13357
                                          • ROMANIA
                                          #620
                                          Regards,
                                          Tomcsa
                                          the posted bios is corrupt ... try this ..
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
