HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1514
    • Estonia
    #681
    Re: HP BIOS unlock tool
    Hot air, yes. Settings depend on your station (no point in telling what you have. They vary even between same model). No need to be scared about high temperature if its an elitebook. I don't even remove the motherboard from case on 840G3.
    You can use soic8 clip on wson8 when it's unsoldered. Just might take a few tries to get a proper connection on it. I am using some wson8 socket, just to save time. But these sockets aren't cheap.
    • snoogy
      • Nov 2016
      • 17
      • england
      #682
      Thats great advice.. thank you for taking the time to reply me.. I appreciate it.. had you been in the UK I would have sent the mobo off to you as you seem a professional..
      Stay safe..
      • Teeri
        • Jan 2014
        • 12
        • Finland
        #683
        Thank you for this program. I just succesfully unlocked 3 HP Elitebook 840 G1's and 3 HP Elitebook 820 G1's that I found in garbage.
        I did not even have to unsolder the chips.
        I used cheap soic-8 clip, raspberry zero and flashrom.
        Trick was to first remove battery if present, then connect power adapter and turn the laptop on and press F1 to display device info. (It propably does not have to be device info, any other menu will propably do) Then I turned the laptop off from the power key and connected the soic-8 clip. Make sure you have good connection and DON'T connect the 3.3V from the raspberry!!!!
        I tranfered the .bin files from my raspberry to my laptop with WinSCP. Then I verifyed the two dumps match and tragged one .bin file to the HPUnlocker.exe in windows explorer. This actually was the hardest part and made no sense for me, but it worked. I tried to run the HPUnlocker.exe several times but it just gives you a error message.
        Then I tranfered the created bios_unlocked.bin back to the raspberry with WinSCP and flashed it with flashrom and Bob's your auntie!
        Now I have 6 working and bios unlocked elitebooks. My family members will be so happy to get some "new" laptops.
        • Didier91
          • Feb 2021
          • 4
          • France
          #684
          Good morning all.
          I bought a cheap HP EliteBook Folio 1040 G3 from a brooker.
          It works perfectly but the bios is locked and I cannot boot from an external medium (USB stick for example) to put everything back in order as new.
          By reading and re-reading this thread I learned that it was doable and without too much effort.
          I ordered an EZP2019 type programmer and lots of adapters.
          First, I will use the soic-8 clip with the correct procedure. If I can not have several identical dump (4 or 5), I'll unsolder.
          Everything is clear in my head but in all my reading, I cannot find a software reference to drive this EZP2019.
          Do you have a specific and reliable program name that I can safely use (not in Chinese, please).
          Thanks for all of this reading and for your help.
          Regards,
          Didier.
          • wienie1983
            • Nov 2016
            • 3
            • Romania
            #685
            Need help unlocking bios password HP Zbook 17 G5
            • peste
              • Dec 2016
              • 12262
              • ROMANIA
              #686
              try the first time and only rewrite, the 16mb one with z17g5origa, if it doesn't work, rewrite both bios with the other two ...
              • tim9
                • Feb 2021
                • 11
                Guys I need help.
                My Laptop : HP Elitebook 840 G3 (Touch version)
                It was locked so I successfully unlocked it and updated bios to latest.
                somehow bios chip was not properly soldered so it was showing flashing LED.
                Now I soldered it and but it failed.
                So I took same winbond chip from another board ( matching ) , flashed it with my backed up bios.
                Now laptops starts with blank screen and runs the fan very highest speed for a while and then it goes off. Keeps on repeating the same cycle.
                Not sure what to do next.
                Any ideas ?
                • stars-n-dust
                  • Apr 2019
                  • 59
                  Please unlock the password. Tool worked for 6050A2822301-MB-A01, but not working for 6050A2892401-MB-A01
                  • peste
                    • Dec 2016
                    • 12262
                    • ROMANIA
                    #689
                    Originally posted by tim9
                    Guys I need help.
                    Any ideas ?
                    you have probably read or written the bios chip with errors ... post the bios backup ..
                    • peste
                      • Dec 2016
                      • 12262
                      • ROMANIA
                      #690
                      try..
                      • stars-n-dust
                        • Apr 2019
                        • 59
                        Originally posted by peste
                        try..
                        Password is still there.
                        • peste
                          • Dec 2016
                          • 12262
                          • ROMANIA
                          #692
                          try this
                          • stars-n-dust
                            • Apr 2019
                            • 59
                            try this
                            ''Authentication failed'' right when power the laptop. Had the same problem when manually deleted AdminPW line. Is it something to do with the EC chip?
                            • peste
                              • Dec 2016
                              • 12262
                              • ROMANIA
                              #694
                              post the full name and model of the laptop.
                              • stars-n-dust
                                • Apr 2019
                                • 59
                                hp 840 g3
                                • peste
                                  • Dec 2016
                                  • 12262
                                  • ROMANIA
                                  #696
                                  hp 840 g3
                                  try..
                                  • stars-n-dust
                                    • Apr 2019
                                    • 59
                                    try..
                                    This one works. Thanks a lot!
                                    • wienie1983
                                      • Nov 2016
                                      • 3
                                      • Romania
                                      #698
                                      Many thanks! Works perfectly with both chips writed!
                                      • black0hackers
                                        • Jul 2020
                                        • 365
                                        some one please clear bios password for me thank you!
                                        • peste
                                          • Dec 2016
                                          • 12262
                                          • ROMANIA
                                          #700
                                          try..
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • iZakre
                                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                            by iZakre
                                            Hello everybody!
                                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                            The thing is that I had installed TeamViewer and could log into the computer...
                                            02-19-2023, 02:27 PM
