Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
  • Mario1241
    • Jun 2022
    • 24
    • Mexico
    #281
    Re: Macbook M1 bypass FMM / EFI Unlock
    Originally posted by killeur
    Hello every one,
    i want to thank you all for effort and contribution,
    I was wondring if any one had tried to replace the ssd nand ships and reset the mac from dfu mode using Apple configurator App ? like replacing a normal ssd would that bypass FMM ? i am new so forgive me if iam saying bullshits.
    Regards.
    Hi Killeur,
    you can't with newer macs, since the hard drive is soldered onto the motherboard.
    Cheers!
    • killeur
      • Nov 2022
      • 4
      • djazayer
      #282
      Originally posted by Mario1241
      Hi Killeur,
      Cheers!
      hello Mario,
      thank your for your reply,
      for replacing the ssd nand iam already aware that is soldered to the motherboard, and i didn't say that it will be easy to replace it even more to bypass FMM if the swap is successful.
      but i already read that it is possible with the right skills: https://www.google.com/url?sa=t&sour...q4tYb80tIOUmJ_. (link for an article about Chinese upgrading ram and ssd on m1 model)
      regards.
      • Mario1241
        • Jun 2022
        • 24
        • Mexico
        #283
        hello Mario,
        regards.
        hi killeur
        If it is what I have seen in the information of all the research reading. I haven't tried it because I don't have the tool and the other one is like hitting the tower if I can't make it work again. But this sure the hard drive has to do with the whole crash. And more as it is designed. Look at this.
        https://eclecticlight.co/2021/01/18/...l-and-m1-macs/
        • genhack
          • Sep 2014
          • 16
          • Italia
          #284
          Hi Killeur,
          Cheers!
          No. You need to swap M1 with one clear.
          • aksel3
            • Jul 2016
            • 26
            • turkey
            #285
            hi I have m1 macbook pro max device MDM. I deleted ssd and install new OSX MONTEREY after I said no internet connecting full installed device. I am going to recovery mode
            terminal csrutil disable. gives an error message
            csrutil: the Os environment doesnt allow changing security configuration options.
            Ensure that the system was booted into Recovery OS via the standart user action.
            I need help
            • ethiogsm
              Banned
              • Mar 2021
              • 10
              • ethiopia
              #286
              Originally posted by betonel
              There is some guy on youtube showing how he open terminal inside activation window on M1/T2 mac.
              keywords: M1 terminal inside Internet recovery MacOS Monterey
              How is this possible? We need to find key combination, for the moment found way to open log window / save logs to usb.
              HI ive been doing some research back 2 years ago and i can tell you that it is possible to open terminal on activation recovery only on T2. the command is you press repeatedly command+T (terminal) right after you select language.
              ive tried this on M1 but doesnt work.
              • ethiogsm
                Banned
                • Mar 2021
                • 10
                • ethiopia
                #287
                Here are some of the pictures i took while opening terminal on activation lock screen on T2 using the command+T
                • aksel3
                  • Jul 2016
                  • 26
                  • turkey
                  #288
                  I need help
                  SOLVED:I showed ssd as startup disk. after restart.
                  recovery mode and terminal csrutil disable
                  bingo worked .
                  after I paid check_m8 for mdm bypass software. it is working now without MDM.
                  • 777monah777
                    • Oct 2022
                    • 9
                    • Washington
                    #289
                    Hi. Can't activate terminal with command+t on m1
                    • kevingill
                      • Jun 2013
                      • 152
                      • England
                      #290
                      Is that exploit on the old bridgeos?
                      • Mac2vn
                        • Nov 2022
                        • Viet nam
                        #291
                        Thank so much for sharing.
                        • killeur
                          • Nov 2022
                          • 4
                          • djazayer
                          #292
                          hello ethiogsm,
                          may i ask you how to open terminal on T2 mac on wich step you did that ? i need your assistance to reproduce it please. i tried to hold cmd+t with no success.
                          thanks in advance.
                          • Mario1241
                            • Jun 2022
                            • 24
                            • Mexico
                            #293
                            hello
                            I share that yesterday I started to compare the information of my mac M1 unlocked and locked.
                            I used the hidden menu on the unlocked M1 and found that the preboot drive had 3 files and the locked mac only had 2.
                            What I see is that the unlocked one has a file called active.
                            Do you think this is the one in charge of having the pc unlocked, I tried to copy it but I have no way, how do you see? what do you think?
                            Cheers!
                            • ethiogsm
                              Banned
                              • Mar 2021
                              • 10
                              • ethiopia
                              #294
                              hello ethiogsm,
                              thanks in advance.
                              Hi killeur
                              you just press the key command+T repeteadly in recovery screen while you are at the language selection part.
                              • killeur
                                • Nov 2022
                                • 4
                                • djazayer
                                #295
                                Hi killeur
                                hello ethiogsm
                                thanks for your return, even with internet recovery does that work ? another question does the workaround also work with Monterey?
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  #296
                                  I've posted a method of accessing a Terminal in the thread about unlocking T2 based Macs.
                                  • genhack
                                    • Sep 2014
                                    • 16
                                    • Italia
                                    #297
                                    Broh this is so.... I have no idea how you spwn. I can't dm you idk why, so if you can pls do it. If not, you edit some info.p and change the iA_springboard?
                                    • nomade
                                      • May 2022
                                      • 6
                                      • Peru
                                      #298
                                      Has anybody tried to startup a locked M1 with a working OS installed on external drive?
                                      Maybe someone could share a image of a running MACOS installation for M1 to try it myself.
                                      Thanks in advance and thanks to everybody for sharing your knowledge.
                                      • ethiogsm
                                        Banned
                                        • Mar 2021
                                        • 10
                                        • ethiopia
                                        #299
                                        I can't dm u either it's weird
                                        • ethiogsm
                                          Banned
                                          • Mar 2021
                                          • 10
                                          • ethiopia
                                          #300
                                          Anyhow I've got all decrypted ssh logs and files of mina emc checkm8 and iremove T2 bypasses
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • oxonater
                                            Apple MacBook Pro A2141 16" IC BYPASS
                                            by oxonater
                                            Hi everyone hope all are well
                                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                            I suppose it's worth noting googling the part package brings up various...
                                            10-23-2024, 11:21 PM
                                          • keats11
                                            T2 Macbook MDM Unlock by S/N change.
                                            by keats11
                                            I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                            05-15-2023, 06:46 AM
                                          • Manlikeissak
                                            M1 MacBook EFI/FMM unlock
                                            by Manlikeissak
                                            Hello everyone hope you all are doing well, I'm posting here since no was interested in my post on "MacBook unlocked!" Topic, so In short I have found a way to test every possible key combination to try and find the combination to open the terminal on fmm/EFI locked M1/M2 machines, the person who found this still refuses to give info, but if hasn't lied about it being a key combination there's a chance we might find it, so to try Evey key combination I've got a digispark attiny 85 which is a small μController, I've written as script to emulate a keyboard and go thru every possible key...
                                            07-02-2024, 11:28 AM
                                          • tobeend
                                            Bypass iCloud MACBOOK t2 iBridge older 7.0
                                            by tobeend
                                            Does anyone know any solution to bypass the older iBridge?
                                            because everyone now offers bypass only 7.2 and 7.4 as they are not so stable and I don't want to update from 5.5 to 7.5
                                            Please suggest a way out of the situation
                                            05-26-2023, 07:32 AM
