Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
Re: Macbook M1 bypass FMM / EFI Unlock
I had already commented something about this, check my post.Hello, I hope not making a mistake in this forum, im trying to understand how the system works, AND i am searching on the web what function have those files that appear in the system by pressing
Shift+control+options+command+.
When i try to access to wifi the first Time after resoration, one of the files created make me remember when i bypassed an iPhone years ago. The file Is *data_ark.plist* I Will be uploading the Rute, in the past this file was needed to modify some lines to make iphone bypass, and also was an app to do the work, if someone know how to View the code It Will be great.
Sorry, im not a programmer, and i not have to much knowledge about macs, im just starting this week to search, maybe there are people that tried this, If that the case, I apologize.
Cheers!Comment
Oh I see, sorry. Hey, did you try Betonel method? Modifying that ipsw file? UniversalMac_11.0.1_20B29_Restore.ipsw\022-10604-034\3_Apple_APFS, You asked if there was a vídeo.
I send you a message in spanish.Comment
Did you try modifying ipsw yourself? And what was the outcome if you did?Comment
Hi, can you send a mp please sorry my inglishComment
We need to determine how the bootloader unlock is actually performed, whether its a bit flip on the SSD or in the SEP. If it's in SEP, you're shit out of luck. If it's in the info partition then there may be a way to unlock it manually with write access to the chip. Seems unlikely of Apple to overlook such a glaring security hole though, so don't hold your breath. If someone can gain code execution prior to activation then there may be a way to unlock iBoot and install Asahi or a modified macOS install with activation lock removed. Any method of loading m1n1 would result in a complete iCloud bypass with minimal additional work depending on whether you'd like to use the machine for Linux or macOS.Last edited by TheSynthax; 12-06-2022, 12:14 PM.Comment
time to hit the books then i guessWe need to determine how the bootloader unlock is actually performed, whether its a bit flip on the SSD or in the SEP. If it's in SEP, you're shit out of luck. If it's in the info partition then there may be a way to unlock it manually with write access to the chip. Seems unlikely of Apple to overlook such a glaring security hole though, so don't hold your breath. If someone can gain code execution prior to activation then there may be a way to unlock iBoot and install Asahi or a modified macOS install with activation lock removed. Any method of loading m1n1 would result in a complete iCloud bypass with minimal additional work depending on whether you'd like to use the machine for Linux or macOS.
just some spitballing - apologies for my ignorance as im noob - would it be possible to
1) get a m1n1 environment with a startup disk? as in run a live session from a usb drive. there also seems to be an ability to load shares over a network using the ol diagnostics tool trick.
2) install something malicious in DFU mode that could trigger running the asahi installer / image
They have a nice serial tool https://github.com/AsahiLinux/macvdmtool but it requires dropping some security (which it seems my mac mini has enabled still)..
My goal is to bypass activation too but I would be content with a linux machine as well.. there was a user in this thread who claimed to have a working linux system so it has to be possible.. (or hes lying)Last edited by dr.d3x; 12-07-2022, 06:09 PM.Comment
@genhack @ethiogsm @mario1241 have you all made any progress? I have an FMM m1, happy to try some things, it’s a paperweight alreadyComment
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...-
Channel: Schematics and Boardviews
by D6iHello everyone,
I accidentally locked myself out of my MacBook Air 2017 after a failed OpenCore installation. I need an SCBO file to reset the firmware password.
Model: MacBook Air 2017
Hash Code: FV9749303Q4J22GDC35A225DD456B2B91
Thanks in advance for your help!2 Photos-
Channel: BIOS Requests ONLY!
by taptiicHello everyone, I need help with a MacBook
My classmate just sold me this MacBook today, and i tried to enter recovery mode to reinstall macOS, and there is a efi lock
Don’t ask me for EFI dump, I don’t have a programmer.
Serial number: C17J5KZ8DRVC
I’ll hope for community’s help!
1 Photo-
by amigo744hello there,
imac m3 from 2023 icloud locked
is there any icloud bypass or unlock.
on youtube there is a service unlocks hub.
does anybody here know them and can tell experience ???12-21-2025, 11:39 AM - Loading...
