Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
  • techman9510
    • Jul 2018
    • 10
    • usa
    #161
    Re: Macbook M1 bypass FMM / EFI Unlock
    Originally posted by sangnm1987
    Could you explain the "Business Apple ID"? Does it allow supervisor to stay on top of their devices including MDM? Thanks
    so my plan was to write the sn, wifi/bluetooth address to a T2 MacBook and activate it with checkm8 and from their supervise the device with apple configurator 2. in order to get a MDM activation key you need to have a business Apple ID or school Apple ID. once you have it signed up you will get an activation key and from their put that activation key on the locked m1 and it should in theory bypass it because that activation key is tied to the sn and wifi/bluetooth address. but its all a theory and I don't have a business Apple ID and I don't have to tools reprogram the Nand on the T2 MACBOOK. and I also have no way of getting the wifi/bluetooth Mac address from the M1 MACBOOK. honestly getting the Mac address from the locked M1 is the biggest challenge.
    • sangnm1987
      • Mar 2021
      • 5
      Thanks for the info.
      • walou
        • Apr 2022
        • algeria
        #163
        Hello
        to have the wifi mac just use your wifi in the activation lock screen and check the router configuration page to see the connected devices , i was able to retrieve the wifi mac but still dont have any idea how to get the bleutouth mac
        • walou
          • Apr 2022
          • algeria
          #164
          otherwise the bt and wifi mac are used to generate the UUID which i think is used to apple for activation lock .
          i'v found how the iphone UUID are generated but there is no information for macbook devices , my plan is to use VM and edit the config file to edit the uuid
          i'v tried it with sn and linked the VM to my icloud and it sent the modified SN that i'v entered
          • VHS
            • Oct 2020
            • 13
            There are Bluetooth sniffers. Getting it's address should be as easy as the wifi one.
            • lotus1
              • Apr 2022
              • Pakistan
              #166
              Hi, is there any update regarding M1 chipset bypass?
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1355
                • France
                #167
                Originally posted by piernov
                Last character matters too, there can be some overlap between different models.
                I often see problems in the serial decoder algorithms.
                Especially on iphones with colors and storage.
                Does this happen to you too?
                I looked at how it was calculated.
                this diagram is reproduced on all iphone models with a rotation
                XS Max (last digit)
                Space Gray- 1 64 4 256 7 512 c 64 g 256 k 256 n 64 R 256 W 512
                Silver------- 2 64 5 256 8 512 d 64 h 256 l 512 p 64 T 256 X 512
                Gold ------- 3 64 6 256 9 512 f 64 j 256 m 512 Q 64 V 256 Y 512
                the letters AEIOUBSZ are also prohibited here
                • ace.code
                  • Apr 2016
                  • 133
                  • Estonia
                  #168
                  just a stupid a qst... how can you check if a macbook is bypassed or not .
                  is check by serial on paid website enough???
                  • abadcap
                    • Jan 2020
                    • 8
                    • 342A
                    #169
                    If you check it online with a paid service (FMM) and the result shows "ON", but the Mac is not linked to your AppleID, then the device was most likely bypassed.
                    I suppose there is only one way how you can find it out for free: You do restore the bridgeOS and after install the macOS.
                    • ismailweb
                      Banned
                      • Jul 2015
                      • 16
                      • France
                      #170
                      Originally posted by bluestone
                      How do you get the info from the mac itself? I have A1932. with EFI and Icloud locked but its not erased
                      contact me in inbox
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        Originally posted by ismailweb
                        contact me in inbox
                        You no longer have an inbox....and if you put that link back in your profile, you'll be permanently banned.
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                        • ismailweb
                          Banned
                          • Jul 2015
                          • 16
                          • France
                          #172
                          I have solution for remove and byoass
                            • 21969
                            You are banned.
                            • tungtuoitinh
                              • Feb 2022
                              • 10
                              • Vietnam
                              #174
                              Originally posted by betonel
                              Winbond chip is located on the back side of the board similar with T2 models. Attached you can find some pictures of what I've done. Be careful, it's 1.8V chip, so you need to use appropriate programmer adapter.
                              If you wonder what kind of wires I've used.. it's old pc IDE cable
                              Instead of wasting money on T203 (~$200) and get stuck with uson4*3 or DS809SE (~$200) which is exactly an R809F i use this:
                              64$ RT809F + 15 adapters ( 1.8V adapter required!)
                              https://s.click.aliexpress.com/e/_A6uAnD
                              Programmer ( same as DS809SE )
                              25$ MacBook Apple Notebook Maintenance Serial Number Modification Tool T2 Chip Unlock BIOS Read Adapter Board
                              https://s.click.aliexpress.com/e/_ApVJfz
                              Let us program USON2*3 U3750+U3710 Wifi+BT ROM, XSON4*4, Apple T2 ROM USON 4*3 and Macbook M1 SOC, WSON6*5, WSON**6 and WLCSP 16 ball used on A1534 bios or SSD rom.
                              $52 Sam Connector with Seat Socket Serial Line for DS809SE
                              https://s.click.aliexpress.com/e/_A0aPKx
                              Small mod is required to work with RT809F: undo all pins from connector and put it reverse way -> red will be on opposite side , and run a wire from PIN 8 (+) to pin 8 on the board , which you can hold it by hand, without needing to power on MB machine.
                              in this image, i can see you use apdapter "DIP8 to SOP8 0.65mm" to read Uson8 4*3 T2 chip, does it fit?
                              sorry for dumb question because im a newbie and I'm a knowledge seeker
                              Sr english not my main language,
                              Hope you reply me soon
                              • kevingill
                                • Jun 2013
                                • 152
                                • England
                                #175
                                A DIP8 to SOP8 won't work.
                                You need a board from AliExpress called "serial number modification tool T2 chip unlocking BIOS reading adapter board" as posted by betonel.
                                This has USON8 and other types of useful pinouts.
                                • tungtuoitinh
                                  • Feb 2022
                                  • 10
                                  • Vietnam
                                  #176
                                  thanks for answer, but my Macbook in new version bridgeOS, hope checkra1n team do something
                                  • curiositymaster
                                    • Apr 2021
                                    • 45
                                    • Nigeria
                                    #177
                                    We're all waiting for new checkra1n release as it stands.
                                    • tungtuoitinh
                                      • Feb 2022
                                      • 10
                                      • Vietnam
                                      #178
                                      over 20$ in my country very expensive, what do you think when I use copper jump wire to connect T2 Rom chip in Adapter "DIP8 to SOP8"
                                      • mazoot
                                        iFixit
                                        • Jan 2019
                                        • 41
                                        • Moldova
                                        #179
                                        lifehack to all you
                                        Kill the state in yourself and you will be free like a wind...
                                        • tungtuoitinh
                                          • Feb 2022
                                          • 10
                                          • Vietnam
                                          #180
                                          oh, really? i see in this picture, you are using "DIP8-SOP8 0.65mm". does it fit for "uson8 4*3 "???
                                          and why you add capacitor to transistor and jump to 8 pin adapter? ( I think it convert 3v3 vol to 1.8V to use with t2 chip )
                                          sorry for dumb question, i am a newbie D
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • oxonater
                                            Apple MacBook Pro A2141 16" IC BYPASS
                                            by oxonater
                                            Hi everyone hope all are well
                                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                            I suppose it's worth noting googling the part package brings up various...
                                            10-23-2024, 11:21 PM
                                          • keats11
                                            T2 Macbook MDM Unlock by S/N change.
                                            by keats11
                                            I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                            05-15-2023, 06:46 AM
                                          • envym
                                            by envym
                                            Hi everyone!
                                            06-27-2025, 08:54 AM
                                          • Flasman90
                                            Macbook Pro DFU Restore Issues
                                            by Flasman90
                                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                            08-30-2025, 10:27 AM
