Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
    Re: Macbook M1 bypass FMM / EFI Unlock
    ah, sorry, i understand rightnow, you adding AMS1117 1.8V to convert 5v usb --> 1,8v for vcc T2 rom,
      A 3.3v to 1.8v adapter is only $5.
      Bear in mind that you’re repairing a MacBook worth $500-$2000. A $20 investment is worth it to have the correct tools.
        thanks, i will waiting for checkra1n release new version , and i will buy full tool,
        hope it comes out soon
          I have read the right NAND on M1 A2338
          https://drive.google.com/file/d/1mQo...ew?usp=sharing
          Here is the data. I can't see the serial number
            Here is data from the left NAND
            https://drive.google.com/file/d/1yVm...ew?usp=sharing
              I believe it's encrypted and I don't know how to decrypt.
                I have read the data with HxD software and tried decoding with all available options, but none decode to anything that makes sense.
                  I have also installed both NANDs to a known working iPhone X so I can read the data with Purple Mode. When NAND is installed, the phone goes in recovery mode and purple mode fails to connect. When I try to restore software with iTunes it gives error 4014 because underlaying data is not correct.
                  So no luck in reading the SN from M1 Mac NAND with this method.
                  I will try to read data from my personal mac and write it to this locked mac and test
                    If you do a full nand read, try to backup winbond chip also as a pair, it migh hold some keys to open data on ssd.
                      Here is the SOCROM read .bin fine from MDM Locked M1 Mac
                      https://drive.google.com/file/d/1LQI...ew?usp=sharing
                      It is not Windbond, in my case it is Macronix.
                        I checked your bin file and I found a serial number which leads to an IPhone 12 Pro 128GB Pacific Blue A2407
                          Hi I'm keen to volunteer if you are still looking ? Cheers Karl
                            hi guys. i have a macbook air m1 apple silicon. unfortunately he has a locked apple id and broken screen. if connect use type-c to hdmi adapter, i have no image. please say to me how can i get image from recovery assistant. thank you. sorry for my english
                              On older Macs, removing the internal display connector will force the Mac to use an external display.
                              On the subject of it being locked, I’m afraid you’ll have to wait for an unlock to be made available on here.
                                On the subject of it being locked, I'm afraid you'll have to wait for an unlock to be made available on here.
                                yes sir. i turned off the internal display, but dont get picture on external monitor.
                                  oh. im get image but i have no wi-fi settings. the device required internet connection
                                    my device can unlock with apple id, device password and MDM key. im ready connect to your research. i have professional tools (hot air, solder station, microscope, programmer) and skills.
                                      this is my bin file.
                                      p.s eeprom memory tolerant to 3 volts
                                        Is there a way to bypass icloud for macbook pro m1 pro 2021?
                                          The seem question
                                          A2442 - EMC 3650
