T2 Macbook MDM Unlock by S/N change.
  • keats11
    • Nov 2012
    • 88
    • fixing electronics, music.
    I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I connect my wife's Macbook to it, it says some thing "Apple controller" and when I try to restore it or do any operation it simply says "Cannot perform the action" (or something very similar). Can you help me here? The board seems to be developing PPBUS_G3H =12V right now, so it seems to be alive except no boot. Looking for an outline of the S/N number change and DFU update process by anyone with experience.
  • ansen43
    • May 2013
    • 10
    • ireland
    Re: T2 Macbook MDM Unlock by S/N change.
    i got one similar problem two days ago, got a MDM locked machine in and change s/n, but i changed to a working s/n. so boot up no problem. just having activating problem. so i try few other s/n, no luck, i thing someone in this forum said that they linked to wifi and bluetooth now. so i wright the original s/n back, macbook working fine, but surprised that the MDM is gone.so you can try some other working s/n, and wright the original s/n back and see if this works for you.
    • taptiic
      MacBook Air A1466 (13” Mid 2012) EFI Password Unlock Request
      by taptiic
      Hello everyone, I need help with a MacBook
      My classmate just sold me this MacBook today, and i tried to enter recovery mode to reinstall macOS, and there is a efi lock
      Don’t ask me for EFI dump, I don’t have a programmer.
      Serial number: C17J5KZ8DRVC
      I’ll hope for community’s help! ...
      01-09-2026, 11:19 AM
    • som_b1
      Macbook pro T2 chip change
      by som_b1
      Hello. I'm interested in this topic)) - will the T2 chip from the MacBook Pro 13 fit the MacBook Pro 16 of the same year, the same SSD size? Maybe someone has tried it?
      11-05-2025, 12:11 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
