Macbook M1 bypass FMM / EFI Unlock
This topic is closed.
  • tungtuoitinh
    • Feb 2022
    • 10
    • Vietnam
    #181
    Re: Macbook M1 bypass FMM / EFI Unlock
    ah, sorry, i understand rightnow, you adding AMS1117 1.8V to convert 5v usb --> 1,8v for vcc T2 rom,
    • kevingill
      • Jun 2013
      • 152
      • England
      #182
      A 3.3v to 1.8v adapter is only $5.
      Bear in mind that you’re repairing a MacBook worth $500-$2000. A $20 investment is worth it to have the correct tools.
      • tungtuoitinh
        • Feb 2022
        • 10
        • Vietnam
        #183
        thanks, i will waiting for checkra1n release new version , and i will buy full tool,
        hope it comes out soon
        • niksamarkovic4
          • May 2021
          • 5
          • Hrvatska
          #184
          I have read the right NAND on M1 A2338
          https://drive.google.com/file/d/1mQo...ew?usp=sharing
          Here is the data. I can't see the serial number
          • niksamarkovic4
            • May 2021
            • 5
            • Hrvatska
            #185
            Here is data from the left NAND
            https://drive.google.com/file/d/1yVm...ew?usp=sharing
            • kevingill
              • Jun 2013
              • 152
              • England
              #186
              I believe it's encrypted and I don't know how to decrypt.
              • niksamarkovic4
                • May 2021
                • 5
                • Hrvatska
                #187
                I have read the data with HxD software and tried decoding with all available options, but none decode to anything that makes sense.
                • niksamarkovic4
                  • May 2021
                  • 5
                  • Hrvatska
                  #188
                  I have also installed both NANDs to a known working iPhone X so I can read the data with Purple Mode. When NAND is installed, the phone goes in recovery mode and purple mode fails to connect. When I try to restore software with iTunes it gives error 4014 because underlaying data is not correct.
                  So no luck in reading the SN from M1 Mac NAND with this method.
                  I will try to read data from my personal mac and write it to this locked mac and test
                  • betonel
                    • Nov 2015
                    • 32
                    • romania
                    #189
                    If you do a full nand read, try to backup winbond chip also as a pair, it migh hold some keys to open data on ssd.
                    • niksamarkovic4
                      • May 2021
                      • 5
                      • Hrvatska
                      #190
                      Here is the SOCROM read .bin fine from MDM Locked M1 Mac
                      https://drive.google.com/file/d/1LQI...ew?usp=sharing
                      It is not Windbond, in my case it is Macronix.
                      • alerm
                        • Mar 2022
                        • 16
                        • Deutschland
                        #191
                        I checked your bin file and I found a serial number which leads to an IPhone 12 Pro 128GB Pacific Blue A2407
                        • mastak07
                          • Aug 2015
                          Hi I'm keen to volunteer if you are still looking ? Cheers Karl
                          • tiny13
                            • Jul 2022
                            • 17
                            • russia
                            #193
                            hi guys. i have a macbook air m1 apple silicon. unfortunately he has a locked apple id and broken screen. if connect use type-c to hdmi adapter, i have no image. please say to me how can i get image from recovery assistant. thank you. sorry for my english
                            • kevingill
                              • Jun 2013
                              • 152
                              • England
                              #194
                              On older Macs, removing the internal display connector will force the Mac to use an external display.
                              On the subject of it being locked, I’m afraid you’ll have to wait for an unlock to be made available on here.
                              • tiny13
                                • Jul 2022
                                • 17
                                • russia
                                #195
                                On the subject of it being locked, I'm afraid you'll have to wait for an unlock to be made available on here.
                                yes sir. i turned off the internal display, but dont get picture on external monitor.
                                • tiny13
                                  • Jul 2022
                                  • 17
                                  • russia
                                  #196
                                  oh. im get image but i have no wi-fi settings. the device required internet connection
                                  • tiny13
                                    • Jul 2022
                                    • 17
                                    • russia
                                    #197
                                    my device can unlock with apple id, device password and MDM key. im ready connect to your research. i have professional tools (hot air, solder station, microscope, programmer) and skills.
                                    • tiny13
                                      • Jul 2022
                                      • 17
                                      • russia
                                      #198
                                      this is my bin file.
                                      p.s eeprom memory tolerant to 3 volts
                                      • Eltabry
                                        • Jul 2022
                                        • Egypt
                                        #199
                                        Is there a way to bypass icloud for macbook pro m1 pro 2021?
                                        • multihad
                                          • Jul 2022
                                          • Morocco
                                          #200
                                          The seem question
                                          A2442 - EMC 3650
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • oxonater
                                            Apple MacBook Pro A2141 16" IC BYPASS
                                            by oxonater
                                            Hi everyone hope all are well
                                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                            I suppose it's worth noting googling the part package brings up various...
                                            10-23-2024, 11:21 PM
                                          • keats11
                                            T2 Macbook MDM Unlock by S/N change.
                                            by keats11
                                            I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                            05-15-2023, 06:46 AM
                                          • Manlikeissak
                                            M1 MacBook EFI/FMM unlock
                                            by Manlikeissak
                                            Hello everyone hope you all are doing well, I'm posting here since no was interested in my post on "MacBook unlocked!" Topic, so In short I have found a way to test every possible key combination to try and find the combination to open the terminal on fmm/EFI locked M1/M2 machines, the person who found this still refuses to give info, but if hasn't lied about it being a key combination there's a chance we might find it, so to try Evey key combination I've got a digispark attiny 85 which is a small μController, I've written as script to emulate a keyboard and go thru every possible key...
                                            07-02-2024, 11:28 AM
                                          • tobeend
                                            Bypass iCloud MACBOOK t2 iBridge older 7.0
                                            by tobeend
                                            Does anyone know any solution to bypass the older iBridge?
                                            because everyone now offers bypass only 7.2 and 7.4 as they are not so stable and I don't want to update from 5.5 to 7.5
                                            Please suggest a way out of the situation
                                            05-26-2023, 07:32 AM
