Extract bios password from EliteBook 840 G8 Bios dump, possible?
elitebook 840 g8 Locked bios PLs
SN=5CG3232JJT
motherboaerd number = 6050a3426501-mb-a02Attached FilesComment
CTNumber_6LGWQ0QWYHZ2XC
Serial_5CG3232JJT
Sku_6L8D7EC#ABD
Fearture byte_476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAeMfPguhKhkjhk8mEmVn7nVngpDpnpqpr.fR
Build Id_21WWCVFZ601#SABD#DABD
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Try this dumpsAttached FilesComment
HELLO
MY LAPTOP HAS NO DISPLAY. SN:5CG20881MJ
CAN SOMEONE HELP ME WITH CLEARME
TIAAttached FilesComment
Clean what ? ,please explain what the problem is in more detail, and read the rules, post (Type) the laptop serial number -> https://www.badcaps.net/forum/troubl...before-postingComment
MY LAPTOP HAS NO DISPLAY. 840 g8, SN:5CG20881MJ
CAN YOU HELP ME
I have Elitebook 840 g8 with no Display
s.no. 5CG20881MJ
i5 11th gen
Come some help me
I have attached the bios file.
I have read the guidelines.Attached FilesComment
Hello everyone i have a problem with my elitebook 840 G8 Bios password When i flash unlocked ec file the original bios has recovered and i can't update the bios without password
I trayed many files main and ec bios unlocked
Can someone resoled this problem ?Comment
Write both contents.
You need to enter DMI info with BCU because will enter in manufacturing mode (I hope...)
Here it is:
Description: HP EliteBook 840 G8 Notebook
Serial Number: 5CG3232JJT
Product Number: 6L8D7EC#ABD
Board CT Number: PQSNT00WBI61KL
BuildId(BID): 21WWCVFZ601#SABD#DABD
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAeMfPguhKhkjhk8mEmVn7nVngpDpnpqpr.fR
MAC Address: BC-0F-F3-40-91-E3
If this will not work, I don't have any other solution.Attached FilesComment
OK. Let's put the big guns on this HP840G8
Here it is:
If this will not work, I don't have any other solution.Comment
HP Elitebook 840 G8
SN/ 5CG14111D8
NO Power problem
please rebuild my biosComment
Every donation made will go towards server fees and maintenance costs.Comment
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
Password removal option for those who do not have a method through HPUnlocker.
This option saves all information in the BIOS (serial number, Windows key, etc.) and also excludes the appearance of BIOS notifications at startup (hp endpoint security controller problem).
1. Read BIOS (32MB) and EC (16MB) firmware.
Be sure to make backups.
2. EC:
2.1) Copy the area from the original and paste into a clean "EC (16MB) Clean".
Region start - 0, length - DA3000
2.2) Find in "EC (16MB) Clean" and...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
11-06-2022, 05:22 PM -
- Loading...
