Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    #241
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by hunglaptop1102
    password bios. i have mailed by selling patch hex file but not working.
    Originally posted by MaC_ToC
    Sorry to butt into your discussion, but I am currently trying to restore the bios of an Elitebook 840 G8 that is locked by a password. I would like to know if I have the wrong chip and if it is 1 or 2.
    Thank you very much for your future help!
    Chip I found: winbond 25q256jven Is this the right chip?
    Is there another one ?
    As you can see in the post #237, the EC Chip named U366, so looking for it and upload it's content here. If we still need the other Chip will inform you.
    all donations are welcome,
    • MaC_ToC
      • Feb 2023
      • 31
      • France
      #242
      As you can see in post #237, the EC chip is called U366, so find it and upload its contents here. If we still need the other chip, we'll let you know.
      Thank you,
      I don't understand why I have to look at post #237?
      So the chip I found is not the right one?
      Thank you
      • hardware1
        • Sep 2021
        • 2930
        • N/A
        #243
        Thank you,
        Thank you
        The man who attach his EC file in Post #237 named the EC Chip U366, so I tell you to see if your Chip is labeled as U366 on the board or not. Otherwise if you can upload the 2 Chips do it. *Chips could be in SOIC/WSON Package*
        • MaC_ToC
          • Feb 2023
          • 31
          • France
          #244
          ok is this one ?
          So you have to unsolder it. I thought I was going to use a sop8 connector.
          • hardware1
            • Sep 2021
            • 2930
            • N/A
            #245
            ok is this one ?
            Yes, you should desolder it and use a WSON adapter, or you can use WSON clip (I don't prefer that).
            • MaC_ToC
              • Feb 2023
              • 31
              • France
              #246
              [QUOTE=hardware1;1213034]Yes, you should desolder it and use a WSON adapter, or you can use WSON clip (I don't prefer that).
              Ok so I desoldered, I managed to read something where I see the model of the computer and the brand does that mean that the dump worked?
              but I was wrong, it's an 845 g8
              • hardware1
                • Sep 2021
                • 2930
                • N/A
                #247
                [QUOTE=MaC_ToC;1213914]
                Upload the file and we will see if it's good or not.
                • MaC_ToC
                  • Feb 2023
                  • 31
                  • France
                  #248
                  [QUOTE=hardware1;1213919]
                  ok thx
                  • hardware1
                    • Sep 2021
                    • 2930
                    • N/A
                    #249
                    [QUOTE=MaC_ToC;1213924]
                    ok thx
                    Here's your Unlocked Bios, in the first boot go to Bios Menu and disable security options (Default).
                    If the Password still present, upload the other Chip (Main).
                    Your device is (HP EliteBook 845 G8) according to your Serial Number (5CG1511WMY).
                    • MaC_ToC
                      • Feb 2023
                      • 31
                      • France
                      #250
                      [QUOTE=hardware1;1213926]
                      Thank you very much!!! I'll keep you posted!
                      • MaC_ToC
                        • Feb 2023
                        • 31
                        • France
                        #251
                        It works great!!! thank you!!! my 1st pc with hot air desoldering!!!
                        I have to do n HP Zbook 15 where do I go?
                        • JAFATAGNA
                          • Apr 2016
                          • 59
                          • MARRAKECH
                          #252
                          Can anyone help me to unlock THIS BIOS 840 G8
                          • MaC_ToC
                            • Feb 2023
                            • 31
                            • France
                            #253
                            tell us already what you can do because the only solution is to give a dump of the bios
                            • MaC_ToC
                              • Feb 2023
                              • 31
                              • France
                              #254
                              Here is your Unlocked Bios, on first boot go into the Bios menu and uncheck the security options (Default). If the password is still there, upload the other chip (Main).
                              Your device is (HP EliteBook 845 G8) according to the serial number (5CG1511WMY)
                              Since the flash I have a problem with the battery fault code and the battery in windows is either at 100% or 0%. Before it worked fine.
                              Can this be due to the flash?
                              • hardware1
                                • Sep 2021
                                • 2930
                                • N/A
                                #255
                                Try new OS, Bios update or another battery to know where's the problem.
                                • jm801
                                  Banned
                                  • Apr 2020
                                  • 123
                                  • monterrey
                                  #256
                                  Could you help me to unlock this bios has absolute
                                  • chobio
                                    • Feb 2021
                                    • 4
                                    • japan
                                    #257
                                    try
                                    • jm801
                                      Banned
                                      • Apr 2020
                                      • 123
                                      • monterrey
                                      #258
                                      Originally posted by chobio
                                      try
                                      it won't let me deactivate absolut
                                      • jm801
                                        Banned
                                        • Apr 2020
                                        • 123
                                        • monterrey
                                        #259
                                        I also leave ec in case it takes care to remove absolute
                                        • JAFATAGNA
                                          • Apr 2016
                                          • 59
                                          • MARRAKECH
                                          #260
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
