Not working, I repair bios by ogryginal Dell EXE, and clear ME using FIT. Laptop turning ON correcly. Problem is i cant Save Service TAG and laptop always turning ond manufactured mode i show Alt+ F Key to skip that.
Dell G5 15 5500 bios needed
ThanksAttached FilesComment
FOR MONTHS QUIT DELAY
BUILD A COMPLEAT NEW BIOS YOU MAY TRY
Attached FilesLast edited by qayyum786; 12-29-2023, 07:23 AM.Comment
hello
Dell G5 15 5500
motherboard code : 19753-1.
orginal dump deleted...
Service tag : 8FG4103
the bios in the forum works but it turns on automatically and the fan is constantly spinning at high speed.
i cannot save service tag and cannot apply ALT+F to working in normal mod and fan run on full speed
please clean me working orginal dumpAttached FilesComment
hello
Dell G5 15 5500
Service Tag: 8FG4103
Attached Files↵
https://www.badcaps.net/donateComment
Service tag : FFFG403
Can anyone clean old bios? Computer stuck on rebooting and power led flashes a few times. Tried other bios, laptop fans spin at max and reboots.Attached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi! can anyone help me?
my dell G3 15 has NO DISPLAY, I tried different bios here but it turns ON then off.
Service Tag: 2R981B3Comment
st: 7M9PT93
Does the original bios have an image source,, tried another bios flashing 3 yellow 6 white,, please help me fix itComment
hi
I need clean me Region
FT3GF63
RegardsAttached FilesComment
You MUST:- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by re1nholdHello Guys
I'm currently fixing two different Dell latitudes,
I need a E5550 BIOS - SERVICE TAG is: FSFB262
So far I flashed about 6 BIOS from this forum already,
none worked,
only fan spin ~3s, LCD black, keyboard LED on/off ok,
I tried manual extraction with scripts for ages so to speak. VM is untried yet.
This laptop is not burnt, it seems to just have a corrupted BIOS.
I extra baught ram. This has to work friends.
Do you generate it this way in Windows in CMD?:
Code:E5550A24.exe /writeromfile C:\bios.fd
- Loading...
