Dell G5 15 5500 bios needed
  • SComputers
    • Oct 2024
    • 13
    Originally posted by Carlos Simbaña
    It's alive! Now have video, Thank you so much! But it has Alert TPM device is not detected, can that be solved?
    try this one
    • Carlos Simbaña
      • Jun 2024
      • 36
      • Ecuador
      #202
      Originally posted by SComputers
      try this one
      I tried, it´s working perfectly now, thanks a lot, you are the best
      • leonce
        • Mar 2018
        • 21
        • cote divoire
        #203
        hello every one
        i have dell g5 15 5500
        mainboard Selek mlk n18E 19753-1
        Service Tag: deleted from the computer cover, and I don't know how to get it from the dump
        Please clean my file, no display
        • SComputers
          • Oct 2024
          • 13
          Originally posted by leonce
          hello every one
          try this
          • leonce
            • Mar 2018
            • 21
            • cote divoire
            #205
            The fans spin very loudly and after 5 seconds the computer shuts down. When I turn it back on, it's the same behavior. tanks SComputers for your help
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • 417731
              BIOS needed for Dell Vostro 3405
              by 417731
              Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
              Model: Dell Vostro 3405
              Tag:F0B1YF3
              CPU:Ryzen 3500U
              Thanks in advance
              07-06-2025, 06:48 PM
            • re1nhold
              Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
              by re1nhold
              Hello Guys
              I'm currently fixing two different Dell latitudes,
              I need a E5550 BIOS - SERVICE TAG is: FSFB262
              So far I flashed about 6 BIOS from this forum already,
              none worked,
              only fan spin ~3s, LCD black, keyboard LED on/off ok,
              I tried manual extraction with scripts for ages so to speak. VM is untried yet.
              This laptop is not burnt, it seems to just have a corrupted BIOS.
              I extra baught ram. This has to work friends.
              Do you generate it this way in Windows in CMD?:
              Code:
              E5550A24.exe /writeromfile C:\bios.fd
              07-18-2025, 09:18 AM
