Dell G5 15 5500 bios needed
Re: Dell G5 15 5500 bios needed
here are the workers, but an error comes out
Alert! TPM device is not detectedComment
https://www.dell.com/support/kbdoc/e...ecision-or-xps
https://www.dell.com/support/kbdoc/e...-and-bitlocker
Intel PTT must be enabledComment
Dell G5 15 5500 motherboard code : 19753-1.
orginal dump deleted...
Service tag : 6PDS663
the bios in the forum works but it turns on automatically and the fan is constantly spinning at high speed.
please clean me working orginal dump...Comment
Attached FilesLast edited by sunbabu369; 11-22-2021, 11:30 PM.Comment
I think another service has removed the bios chips before.so i can't access the original dumps.it is necessary to extract a bios from the original dell site......Comment
this file both bios flash it and wait display come 100%.check it replay me.Attached FilesComment
Try this 8MB fixed file, and flash the 16MB from post #9Attached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by re1nholdHello Guys
I'm currently fixing two different Dell latitudes,
I need a E5550 BIOS - SERVICE TAG is: FSFB262
So far I flashed about 6 BIOS from this forum already,
none worked,
only fan spin ~3s, LCD black, keyboard LED on/off ok,
I tried manual extraction with scripts for ages so to speak. VM is untried yet.
This laptop is not burnt, it seems to just have a corrupted BIOS.
I extra baught ram. This has to work friends.
Do you generate it this way in Windows in CMD?:
Code:E5550A24.exe /writeromfile C:\bios.fd
- Loading...
