Lenovo V130-15IKB bios dump
  • poweron
    • May 2019
    • 371
    • italy
    #141
    the serial number is R90T71ZK
    thank you
    • poweron
      • May 2019
      • 371
      • italy
      #142
      sorry I must have got the two bios mixed up, now I'll send the correct bekup
      • volinakis
        • Jan 2021
        • 2888
        • N/A
        #143
        try. Thanks goes to SMDFlea, I took one of his bios reported as working and transferred DMI & win key
        • poweron
          • May 2019
          • 371
          • italy
          #144
          ok thanks, I'll try it and update you
          • poweron
            • May 2019
            • 371
            • italy
            #145
            tried it and it works perfectly, thank you very much
            • jonas15
              • Feb 2014
              • 17
              • Lithuania
              #146
              We have problem, with bios. Require special skills in fixing the bios. Bios that we send, does not work. Can someone fix bios dump. BIOS attached
                • 22424
                Type the laptop serial number, full name and model, motherboard model, etc.
                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                • jonas15
                  • Feb 2014
                  • 17
                  • Lithuania
                  #148
                  Lenovo V130-15IKB
                  MODEL NAME: 81HN
                  SN: R90R0KWN
                  MTM: 81HN00H6MX
                  MO: R9N0B8622014
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12521
                    #149
                    Lenovo V130-15IKB
                    MODEL NAME: 81HN
                    SN: R90R0KWN
                    MTM: 81HN00H6MX
                    MO: R9N0B8622014
                    V130-15IKB Laptop (Lenovo) - Type 81HN
                    • jonas15
                      • Feb 2014
                      • 17
                      • Lithuania
                      #150
                      Many thanks for the help.
                      • AHmad_Salal
                        Need BIOS Dump/ROM for Lenovo Thinkstation p500
                        by AHmad_Salal
                        Hello all,
                        I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                        11-28-2023, 05:28 AM
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • hyperwood
                        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                        by hyperwood
                        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                        ✅ What I need:
                        • A working 2MB BIOS dump
                        • Matching NM-E471 Rev. 2.0, e.g. JY575
                        06-25-2025, 02:28 PM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
