Lenovo V130-15IKB bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12521
    #41
    Re: Lenovo V130-15IKB bios dump
    Originally posted by aminealae
    turn on but no display
    Try again
    • aminealae
      • Jun 2013
      • 97
      • morocco
      #42
      Originally posted by hoaca388
      Try again
      nothing no display
      • hoaca388
        Badcaps
        • Jan 2022
        • 12521
        #43
        nothing no display
        Find other issue.
        • aminealae
          • Jun 2013
          • 97
          • morocco
          #44
          Find other issue.
          but why when i flash it by dump on post 11 it work normal one time after reboot give me no display
          • hoaca388
            Badcaps
            • Jan 2022
            • 12521
            #45
            I don't know, if the problem is because bios, there are only 2 states: working or not working, there can't be such a flickering phenomenon. Try replacing the bios chip with a new one and see how it works.
            • aminealae
              • Jun 2013
              • 97
              • morocco
              #46
              ok i have mx25l6473f i can replace it by mx25l6406e
              • hoaca388
                Badcaps
                • Jan 2022
                • 12521
                #47
                I'm not sure. You check their data sheet to see if they are similar. voltage for example.
                • duksis
                  • Jun 2022
                  • Latvia
                  #48
                  Is there any chance to get some old bios .exe update file V130-15IKB?
                  I upgrade my bios to newest from lenovo homepage (8vcn30ww.exe) and it dosen't show screen after windows turn it off. And when I restart or turn it off/on, it dosen't show post screen. Few seconds are black screen and then immediately windows
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #49
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • duksis
                      • Jun 2022
                      • Latvia
                      #50
                      thanks
                      • ronelex
                        • Oct 2016
                        • 195
                        • Philippines
                        #51
                        anyione can help me on my unit, It has a bios issue but after I flash the bios the unit is normal again it has external display ok but in the internal lcd have no display, lcdvcc and backlight input voltage 8.5 is present but the rest is missing
                          • 22424
                          This is the "BIOS Requests ONLY!" sub-forum. Please start a new thread in the main laptop forum -> https://www.badcaps.net/forum/forumdisplay.php?f=23
                          • ronelex
                            • Oct 2016
                            • 195
                            • Philippines
                            #53
                            The unit is the same unit model sir? the unit now is alive and have display on external but non in the lcd in start up, the lcd displays only when it enters or load the OS
                            • ronelex
                              • Oct 2016
                              • 195
                              • Philippines
                              #54
                              here is my back up bios
                              • Actros
                                • Sep 2014
                                • España
                                #55
                                Re: Lenovo bios V330-15IKB
                                try this older version .
                                Thank you very much SMDFlea..it works perfectly bios 8VCN28WW ME_CLEAN.zip
                                • magictouch
                                  • Apr 2021
                                  • 108
                                  • united kingdom
                                  #56
                                  Can someone please unlock the Bios For me, Its lenovo V130-15IKB, thanks In Advance.
                                    • 22424
                                    Your bios version is 8VCN**WW ,use a bios from this thread, copy your DMI from your backup to the new bios using a hex editor,and the password will be gone
                                    HxD hex editor https://mh-nexus.de/en/hxd/
                                    • magictouch
                                      • Apr 2021
                                      • 108
                                      • united kingdom
                                      #58
                                      Sorry no Clue, Can you recommend any tutorial?
                                        • 22424
                                        You can follow this one - https://www.badcaps.net/forum/showthread.php?t=98038 ,if you follow that to the end then you`ll have no problem with this V130-15IKB DMI
                                        See attached pictures for the V130-15IKB DMI off-sets -start and end points to enter into HxD
                                        • magictouch
                                          • Apr 2021
                                          • 108
                                          • united kingdom
                                          #60
                                          I have downloaded the file from the lenovo website and trying to convert it via innoextract but its not converting the file. the cmd open and closeses after 1 second whereas no file is produced.
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
