Lenovo V130-15IKB bios dump
    • 21606
    Re: Lenovo V130-15IKB bios dump
    Originally posted by hdano
    I tried, ended up with dead device again....
    Check your soldering,make sure you havn`t lost any resistors or caps around the bios chip.
    Bios attached,with your DMI.
    • hdano
      • Feb 2015
      • Slovensko
      #102
      Flashed just now, not booting at all, same as I edited.
      I tried flash back my backup, same as before - boot to black screen.
      Flashed back #21, working without WIN key.
      Probably will keep working state and will crack WIN.
      • booolas
        • Oct 2023
        • Portugal
        #103
        Originally posted by duksis
        Is there any chance to get some old bios .exe update file V130-15IKB?
        I upgrade my bios to newest from lenovo homepage (8vcn30ww.exe) and it dosen't show screen after windows turn it off. And when I restart or turn it off/on, it dosen't show post screen. Few seconds are black screen and then immediately windows
        Have you managed to solve your problem?
        Please share your experence.
        I'm on the same boat!
        After pressing power about 30 seconds black screen then lenovo's logo for a few seconds and then windows.
        Thankyou.
        • Wachenaggo
          • Jul 2018
          • 66
          • Philippines
          #104
          post the bios backup
          HELP PLS NO DISPLAY AFTER WINDOWS UPDATE
          device : laptop
          brand : Lenovo
          Serial Number: R90YYJ2A
          model : V130-15IKB
          TYPE: 81HN
          board no: LV315KB MB 17807-3M
          request : with original BIOS No Display, Fan spin, and caps lock on. This happen after failed windows update. Here is the backup​
        • Wachenaggo
          • Jul 2018
          • 66
          • Philippines
          #105
          device : laptop
          brand : Lenovo
          model : V130-15IKB
          TYPE: 81HN
            Vesko356 commented
            Editing a comment
            Thread merged.
            Before making a new thread please read the rules first, so I don't have to move your request at the existing topic again:
            You MUST:
            • Post under a related thread if it exists
            Read the whole thread before asking for help. Everything you need to make yourself a new dump is here in this thread.
        • HaDRFakrrr
          • Mar 2024
          • Česko
          #106
          Hello, help me with Lenovo V330-15IKB 81AX bios dump pleasešŸ™after update bad display, fan spin, and caps lock on. In attached files is original BIOS backup -
          Thank you very much for any help.
            Vesko356 commented
            Editing a comment
            Off topic! This thread is about Lenovo V130-15IKB. Do NOT hijack threads please!
            Use the forum search to find related threads where you can post your request.
        • O.Szilard
          • May 2019
          • 161
          • hungary
          #107
          try..be careful when writing..the bios posted by you is longer ..
          Thank!
          • ITFan
            • Sep 2021
            • 68
            Hello dear forum members.
            I also have a Lenovo V130-15ikb here with the same problem as most of you.
            When switching on, only the capslock button is permanently lit and the power button, fans turn but no image.
            This happened after a bios update.
            Here possibly important data:
            Lenovo V130-15ikb
            Model name: 81HN
            SN: R90RV43F
            MTM: 81HN00E0GE
            MO: R9N0B8925012
            The read bios as a backup can never be complete with the small size, but the bios chip is recognised:
            Manufacturer: Macronix
            Type; Serial Flash Memory
            I'll upload the file for you to view and check. Can any DMI data be found in the small backup file?
            Maybe someone can help me please.
            Best regards to all.
            ITFan
              • 21606
              The bios chip is 64 Mega bits , there are 8 Mega bits to 1 Mega Byte (notice the difference between lower case b and upper case B) . So a 64Mb chip has 8MB in capacity. Your backup is ok.
              Try this https://www.badcaps.net/forum/troubl...55#post1774855
              • ITFan
                • Sep 2021
                • 68
                Hello SMDFlea,
                thank you for your quick reply.
                Unfortunately I have no experience with this, but I'll see what I can do.
                I thought the one I read out was faulty because I got the error when I read it out:
                Test pins...
                Test pins OK
                Read ID Flash...
                JEDEC ID: C22017
                SFDP compatible
                Vcc Supply Maximum Voltage: 3600 mV
                Vcc Supply Minimum Voltage: 2650 mV
                IC not set or changed
                Test pins..
                Test pins OK
                Read ID Flash...
                JEDEC ID: C22017
                SFDP compatible
                Start reading in: 07.09.2024 17:24:56
                End reading in: 07.09.2024 17:25:01
                Read OK
                Auto verify
                Start verify in: 07.09.2024 17:25:01
                error
                address: 5FED
                buffer: 5Cdevice: 56
                Verify false
                Best regards
                ITFan
                  • 21606
                  Hello SMDFlea,
                  Try this bios.
                  • ITFan
                    • Sep 2021
                    • 68
                    Hi again,
                    as you could see earlier in the log file, the reading only took max. 5 seconds!
                    I think this is too short, or is this normal?
                    In combination with the Verify False it would be good to have someone who is fit in the subject check the bios please briefly
                    for content and DMI files before I overwrite it.
                    Best regards
                    ITFan
                    PS: Ahh, you posted shortly before me. I will try, thanks a lot.
                    • ITFan
                      • Sep 2021
                      • 68
                      Something is unfortunately wrong, sorry for the inconvenience.
                      I used before a very simple Eeprom programmer, which worked well.
                      Now, for the first time, I have a more expensive SVOD4 and I only get error messages like the following,
                      maybe I'm doing something wrong, was the bios I read out earlier usable?
                      I thing i search for the old programmer to test, but it was a long time not used, i hope i find it.
                      Software version 0.0.5.4 date 5.08.2024
                      Running Microsoft Windows 10 Home 64 bit
                      Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
                      .NET Framework Version: 4.8 or later
                      Device connected in work mode
                      Firmware version 0.0.4.0 date 5.7.2024
                      SPI25 mode selected
                      Test pins..
                      Test pins OK
                      Read ID Flash...
                      JEDEC ID: C22017
                      SFDP compatible
                      File size : 8388608 byte
                      Start erase in: 07.09.2024 22:00:15
                      End erase in: 07.09.2024 22:00:15
                      Erase OK
                      Start blank check in: 07/09/2024 22:00:20
                      error
                      address: 0
                      buffer: FF device: 0
                      Blank Check false
                      Start blank check in: 07.09.2024 22:00:23
                      error
                      address: 0
                      Blank check false
                      Start erase in: 07/09/2024 22:00:39
                      End erase in: 07.09.2024 22:00:39
                      Erase OK
                      Start blank check in: 07.09.2024 22:00:40
                      error
                      address: 0
                      Blank check false
                        • 21606
                        I read another post recently where there were problems with the SVOD4, i can`t find that thread now. From memory the software had to be downgraded, then it worked OK again. If you can find your old programmer use that and if it doesn`t erase or verify its the chip that is bad. If it erases and writes OK that confirms a problem with the SVOD, or the way you are using it. Did you remove all the old solder from the bios chip, is it sitting OK in the adapter,if thats what you used .
                        • ITFan
                          • Sep 2021
                          • 68
                          I already use the old programmer with the
                          good Pomana Clip. Never had any problems.
                          The PIN check also says that all pins are recognised correctly.
                          I think it will be tomorrow with the search for the old device.
                          Hmm, you write that you should go back to older software, maybe still an option.
                          Thanks for your help anyway.​
                          • ITFan
                            • Sep 2021
                            • 68
                            Hello SMDFlea,
                            I have find and just started with a 5 Euro part ch341a with mod and the AsProgrammer1. 29 and flashed it successfully.
                            Were you able to extract the DMI data from the backup including the uuid?
                            It's a shame that the 5 Euro part does the job while the almost 300 Euro part goes on strike... 😭
                            Thank you very much, if everything was taken over by you at dmi data everything fits, it does boot.
                            Best regards
                            ITFan
                              SMDFlea commented
                              Editing a comment
                              All DMI and win key was ok and copied to your new bios. Happy you fixed it ;-)
                          • ITFan
                            • Sep 2021
                            • 68
                            Hello SMDFlea,
                            thank you!
                            Hmm, then the backup was basically despite the error message
                            of the SVOD4 was ok after all?
                            Thought because this error message came in combination that the readout took only about 4 seconds,
                            the file was defective. With the Ch341a it took much longer! And it didn't give an error message.
                            It would be good to know if the SVOD4 itself is ok.
                            Have you been able to find the thread where this was mentioned before?
                            Best regards
                            ITFan
                            PS:
                            Was this bios you used the newest?
                              SMDFlea commented
                              Editing a comment
                              Can`t find the thread but i might have read about it somewhere else. The bios version don`t know i deleted all the files.
                          • elgoma
                            • Apr 2023
                            • Argentina
                            #118
                            I need the BIOS for a V130-15IKB 81HN serial number R90YYJ4E that turns on and does not give video. I attach the BIOS backup.
                            Thank you very much
                            • peste
                              • 13350
                              • ROMANIA
                              #119
                              Thank you very much
                              try post #96..
                              • elgoma
                                • Apr 2023
                                • Argentina
                                #120
                                try post #96..
                                It does the same thing as with the original BIOS, the machine seems to turn on but without image
                                • AHmad_Salal
                                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                  by AHmad_Salal
                                  Hello all,
                                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                  11-28-2023, 05:28 AM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • hyperwood
                                  [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                  by hyperwood
                                  I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                  The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                  I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                  āœ… What I need:
                                  • A working 2MB BIOS dump
                                  • Matching NM-E471 Rev. 2.0, e.g. JY575
                                  06-25-2025, 02:28 PM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • Joluvillas
                                  Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                  by Joluvillas
                                  Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                  06-18-2024, 10:35 PM
