That worked fine, thank you!
panasonic FZ-M1 BIOS need unlock
Can anyone try to read the password that is in the bios please?
Panasonic FZ-M1
S/N 5ATCA23734Attached FilesComment
https://www.badcaps.net/donateComment
Please, help me remove the bios pass, thanks in advance
Panasonic FZ-M1JE-05VM
0BTTC52898
Attached Files↵
Please help removing password
FZ-M1
FZ-M1JECJXVM
AB0123456789
9ATTC13404
What should I use to flash the ROM? What software?Comment
Every donation made will go towards server fees and maintenance costs.Comment
Hi
I have a FZ-M1 mk1 that has locked BIOS, even boot menu is locked.
OS is win10, I tried to backup the BIOS via afuwin 3.09.03.1462 but it only produces a rom file 5.8M not eg 16MB
Also I opened that file via the UEFITool and I dont see any (encrypted) password under the AMISETSetup areas!!
They are zeroes (wtf!) any clues how to clean the pass ? Thank you!Comment
darn was a task from hell, the BIOS is located under the m'board!!!
attached BIOS of FZ-M1CCAAYBE ser 5ATCA24628
I m very perplexed as there are no encrypted passwords under any AMITSESetup areas....
Attached Files↵
AgainAttached Files↵
thanks I m flashing it now using your previous binary, this time under windows because I think the darn flashrom (linux) does not quite support
the BIOS IC MCIX 25L12873F, (it seems this is picky BIOS as it has OTP memory (?) ) , if my attempt fail I will try the second one binary you gave me
really many thanks!Comment
really many thanks!
The 25L12873F is supported by NeoProgrammer (windows) software. https://www.badcaps.net/forum/troubl...82#post3477982
For linux try IMSProg https://github.com/bigbigmdm/IMSProgComment
thanks! alas IMSProg does not have it... I will try NeoProgrammer if it runs under XP
I mention "XP" as , the only 'windows' system I have is a p3 still running XP
EDIT#
I just noticed that I have the same specs like user kitor ! (same mobo version!)
I even tried the file that the forum prepared to him/her , still same results
I assume the BIOS IC bricked.. or somethingComment
Channel: BIOS Requests ONLY!
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
- Loading...
