Pls help me unlock password bios Panasonic CF-RZ6.
Unlock bios Panasonic CF-RZ6
https://www.badcaps.net/donate -
UnlockedAttached Files↵
https://www.badcaps.net/donateComment
unlockAttached FilesComment
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
Asus S533F serial L6N0CV190141266
Current BIOS firmware version is X521FA-305
Thank you!...-
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... - Loading...
