IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
OK so I've studied the procedure in particular with this video but I don't have a backup of my previous bios healthy, it's corrupt because it was badly flashed precisely.
https://youtube.com/watch?v=NyjflvtmAYA
So how can I start from scratch with an old blank bios and transfer my information to it to generate a special bios with custom dmi? Thanks
sorry when sending the file I uploaded the faulty one that was half written. I downloaded the official bios update directly from the lenovo site, can you help me again? thanks
V15-ADA
Model 82C7
Serial PF2CZ1AN
MTM 82C7S00B00
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
I'm having the same problem as you: no image, even though the PC seems to boot normally.
I hope this helps someone, as I've solved my problem.
If you've read this thread, try reprogramming the BIOS. You've checked, as others have indicated, that DIMM_only is enabled (presence or absence of resistor on the motherboard). So you may have the same problem as me.
At the SODIMM slot where the memory stick is inserted, the pins at the ends (left and right) were unsoldered.
A solder point, and the PC works perfectly.
i attach rar fileAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Serial number /model type etc .........
Respect rules please
I found this in bios update but not sure if it worksAttached Filesif you find these attachements useful please consider making a small donation to the site
My Lenovo 17ADA05 has black screen issue. No fan spin and lights are on.
Maybe somebody could help fix bios. All info attached.
IdeaPad 3 17ada05
SN PF26038B
MTM 81W20016PBAttached Filesif you find these attachements useful please consider making a small donation to the site
Try And FeebackAttached Filesif you find these attachements useful please consider making a small donation to the site
Lenovo V15-ADA NM-D151 Rev 1.0
SN: PF1X22LV
PALES REPAIR THIS BIOSAttached Filesif you find these attachements useful please consider making a small donation to the site
try and feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by PatriarxisHello.
I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
It takes 0.027A and the power button flashing.
All the voltages on the board are ok. 3.3, 5 etc.
Also is charging the buttery .
What else i can check?05-26-2025, 01:03 AM -
First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...-
Channel: BIOS Requests ONLY!
by pcwhiz24Model: Lenovo IdeaPad 3 14ADA05 81W0
S/N: PF2BZS7D
I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
I already have a CH341A programmer...-
by Visual_vtLenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
SSD and BIOS seems to be OK.
Thank you.... - Loading...
