HP EliteBook 745 G5 password
  • mo000
    • Nov 2017
    • 281
    • algeria
    HP EliteBook 745 G5 has an admin bios
    do you have any working dump
    or i use hpunlock tool to unlock the bios
    is there any possible to know the password from the dump .
  • peste
    • 12945
    • ROMANIA
    Re: HP EliteBook 745 G5 password
    post the contents of both bios chips.
    • mo000
      • Nov 2017
      • 281
      • algeria
      is it enough to make a dump with universal bios buckup toolkit or i have to desolder bios chip form motherboard and make a dump by programmer .
      • peste
        • 12945
        • ROMANIA
        remove the bios chip from the motherboard before reading or writing...and use the programmer.
        • mo000
          • Nov 2017
          • 281
          • algeria
          thank you man
          i will do .
          • Gramse
            • Aug 2022
            • sweden
            Hi, i have the same problem and im kinda new to desoldering chips an reprograming. can someone walk me through it?
            sigpicGramse
            • peste
              • 12945
              • ROMANIA
              https://www.youtube.com/watch?v=DWWigscuQDY
              • x.stas.y
                • Jan 2023
                • 5
                Hey all,
                I have some issues with my laptop as well. The first one is a bios password and that's how I got here in the first place. And the other one is my laptop throttling down to 0.38ghz. Everything runs frustratingly slow. And the fan is running at full speed all the time. HWiNFO is telling me something about prochot-ext, so something's definitely wrong here, although all temps are fine. I have played with windows power management options. Let it run with or without the battery, same goes for the power adapter. Reinstalled windows and drivers and tried many things more suggested in all kinds of forums. But no luck so far. My guess would be either something's wrong with the board or bios, because this issue persists even without windows running or no ssd installed at all.
                Regarding the bios issue, I've read all posts in the RCUnlocker thread and have a general understanding of how it all works. Still, this whole reprogramming topic is absolutely new to me so I'm a little at loss here. I took some pictures of all bios-like looking chips I could find. Which chip does what? I've read that U366 should be the right one. But to be 100% sure, which is the one I have to modify regarding a.) the password issue and/or b.) fan speed and throttling issue and lastly c.) something else I didn't think of? Because some users reported fan speed running at 100% after reprogramming, I wonder if this issue is somewhat related to mine.
                I still have to buy all the necessary tools. Would a cheap CH341A programmer be enough (for winbond and issi chips)? I have an old RaspberryPi 2 if it that helps, although I'm not familiar with Raspbian/Linux. For that chip with those 8 tiny legs I guess a test clip would suffice? And for the other ones just soldering some wires to the copper pads nearby? If removing the chips from the board isn't absolutely necessary I'd definitely prefer not to, because I most certainly would break something (and had to buy a hot air station).
                Your help is very much appreciated.
                • peste
                  • 12945
                  • ROMANIA
                  Originally posted by x.stas.y
                  Hey all,
                  to delete the password, post the contents of both 128MB chips, here.....you will need an SPI programmer..I don't know if the programmers you have will help you...you can see what bios chips it supports by searching on the internet..you have this video like example, you can see other...
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11885
                    Hey all,
                    WINBOND 25Q128JVPQ is more available when read with CH341A, post the contents of this chip.
                    • x.stas.y
                      • Jan 2023
                      • 5
                      Thanks for your quick reply, both of you. So I'll get a CH341A programmer then. The other WINBOND 25Q16JVSIQ is not relevant in this process? If so, then there is no need for a test clip. For the other two chips WINBOND 25Q128JVPQ and ISSI IC25LP128 soldering tiny wires to the pads nearby would do the trick? So I don’t have to order a hot air station.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11885
                        Blue : yes, it's non relevant.
                        Red : I'm not sure but you can try.
                        Notice the voltage of the CH341A, the black board type has a default voltage of 5 volts.
                        • volinakis
                          • Jan 2021
                          • 2744
                          • N/A
                          Thanks for your quick reply, both of you. So I'll get a CH341A programmer then. The other WINBOND 25Q16JVSIQ is not relevant in this process? If so, then there is no need for a test clip. For the other two chips WINBOND 25Q128JVPQ and ISSI IC25LP128 soldering tiny wires to the pads nearby would do the trick? So I don't have to order a hot air station.
                          from my experience you only need to modify U366 with RCUnlocker and at 1st boot press F10 to enter bios setup and reset security to defaults in Security Tab.
                          • x.stas.y
                            • Jan 2023
                            • 5
                            Thanks for the heads up regarding the 5v issue with this programmer. I'll have to keep that in mind. Was the U366 chip you have encountered the same one from ISSI or another one? Cause there's not much information on the internet regarding that IC25LP128 chip. Well, there is one that it doesn't work: https://www.badcaps.net/forum/showthread.php?t=114626
                            However, if I'm not mistaken you can add a chip manually to the chiplist.xml, right?
                            • volinakis
                              • Jan 2021
                              • 2744
                              • N/A
                              yes, the same chipset, I am using a RT809H and it has a smart ID for chipset, I don't remember if it recognised as is or something equivalent, I unlocked that laptop few months ago.
                              If you are using CH341A try with ASProgrammer or Neo Programmer, don't use software came with CH341A
                              • x.stas.y
                                • Jan 2023
                                • 5
                                Well, regarding the password, I'm not exactly sure what happened. I couldn't read the content of the 2nd chip (ISSY) yet. But first things first, here is what I did.
                                I did get the CH341A programmer finally and did a 3,3v fix I've found on YouTube. I've made myself some kind of pogo pin contraption so I wouldn't have to solder any wires to the board, but the USB programmer always got disconnected from Windows when making contact. It was like unplugging an USB drive with that typical sound it does. If connected to the board first and then plugging in it wouldn't make any sound at all. Windows device manger wouldn't list the programmer as well. I don't think I have shorted anything, but regardless which chip and how many times I have tried I got the same result. In hindsight, I think it was because I've followed a 3,3v fix guide which involved soldering a wire from pin 9 to the transistor, which I did remove later on.
                                Anyway, worrying I might have shorted something and killed the board for good I have assembled everything back together and as soon as I have connected the battery, the laptop started on its own. But the display wouldn't show anything. I have waited a little bit, then hold the power button to shut it down. Tried again, but this time I got three beeping sounds, followed by two shorter and higher pitched ones, and still a dark display. Again, holding down the power button to shut it down. The only thing that came to my mind was booting while pressing and holding the windows + b key to roll back to a working bios configuration, if I've accidently shorted/screwed up the chip/bios while trying to read the 2nd chip.
                                Well, the laptop did its bios thing for a few seconds and started up Windows just fine. I was so relieved. And on top of that the password was gone. So no bios password anymore. Even without soldering or writing to the chip. So either the rollback removed the password (could this actually be?) or just me messing around with both chips did do the trick. Later on I've realized I shouldn't have let it boot to Windows, even though I was more than happy to see the laptop booting at all after it failed to do so previously. Because then I got a “HP Endpoint Security Controller Problem” warning during startup every time. Resetting the security settings and loading the default bios settings did not help. The 0.38GHz and fan speed issue was not solved as well. So something must be wrong with the board physically.
                                Now to get rid of that “HP Endpoint Security Controller Problem” I saw a post by RethoricalCheese suggesting to clear the VSS region from the main bios chip (WINBOND). While that pogo pin thing didn't work well, I've tried soldering tiny wires to the board, right next to chip. Well, that didn't work as well as I've hoped it would either. I did at least 30 dumps or so and a few of them seemed to be exactly the same (this time without soldered pin 9 to the transistor). I have blanked/FF'ed the VSS region with a hex editor and tried to write that back to the chip. No chance, always got errors while verifying. Didn't matter if 3,3v or 5v. Writing just took so much longer then reading and even that took many attempts to get a few good dumps, which happened to be in a row during the first 10 tries, which I couldn't replicate ever since.
                                Anyhow, now I had to ask somebody to help me desoldering the main chip. Erasing, writing, verifying worked flawlessly. But only without the 3,3v fix at all. The programmer always got disconnected from Windows with 3,3v during the writing process. 3,3v while reading seemed to be working. The chip got soldered back on today, but while doing so one resistor went flying off the board, which can't be found. Oh man, from one problem right to the next one.
                                Does anyone happen to know which resistor goes there, right above the main bios chip? And how about your thoughts regarding the password removal? Could a bios rollback or maybe shortening the chip with a possibly wrong 3.3v fix be the reason why there was no password anymore?
                                • sigh45
                                  • Feb 2017
                                  • 14
                                  HP Elitebook 745 G5
                                  Hi All,
                                  I have a HP Elitebook 745 and after trying to remove the bios password with both the RCUnlocker and the HPUnlocker i get no power with only the charging light flashing 5 times then solid white. I've attached the orginal bios if some kind sole could have a look at it for me. TIA
                                  Cheers
                                  Simon
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    Re: HP Elitebook 745 G5
                                    Originally posted by sigh45
                                    hi all,
                                    i have a hp elitebook 745 and after trying to remove the bios password with both the rcunlocker and the hpunlocker i get no power with only the charging light flashing 5 times then solid white. I've attached the orginal bios if some kind sole could have a look at it for me. Tia
                                    cheers
                                    simon
                                    flash old backup with {password} chk if laptop back to life and work normaly as before
                                    if there is 2 bios than post old bios backup without currection
                                    • sigh45
                                      • Feb 2017
                                      • 14
                                      I've now attached both original bios files. Thanks for your help.
                                      Regards
                                      Simon
                                      • nassih
                                        • Oct 2015
                                        • 276
                                        • morocco
                                        hp elitebook 745 G5 bios
                                        hi i need to unlock this bios password
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
