HP EliteBook 745 G5 password
  • kulokutoys
    • Jun 2010
    • 132
    • Phillippines
    Re: hp elitebook 745 G5 bios
    I used RCunlocker on this one try if its working.
    • nassih
      • Oct 2015
      • 282
      • morocco
      Re: HP EliteBook 745 G5 password
      thanks, I already tried with rcunlocker but not working
      • markovic23
        • Sep 2023
        Re: RCUnlocker
        Hi, I hope you can help me with admin password on a HP Elitebook 745 G5 bios (AMD Ryzen 5 PRO). I have try with RCUnlocker but without success. And now here is backup file. I have did with EZP2023+.
        • peste
          • 14025
          • ROMANIA
          Re: RCUnlocker
          see if you still have a bios chip on the board, post the content.. see on both sides of the board..
          • cheebster
            • May 2008
            • 376
            Hi there, this is caused by PROCHOT being trigged on the RYZEN cpu which is a processor thermal protection. There are many ressources to fix this, but im still at a dead end. Ok i know, doing this we're disabling the thermal protection on the cpu.. But it's better than having a brick. I don't think it's a fire hazard.
            You can confirm this with HwInfo64 also.
            Here's the details on the workaround;
            https://github.com/Hangovers/Amd-sta...mating-the-fix
            This tool/fix would work, but it turns out that AMDRMCLI.exe which is RYZEN MASTER command line utility is not on my pc when i install Asrock motherboard utility 3.0.466, it's just not there in the BIN folder.
            AMD Ryzen master will not install on mobile cpu's either. Kinda stuck for a simple reason, i can't find a copy of ryzen master CLI anywhere.
            Hope that helps.. Thanks
            Originally posted by x.stas.y
            Hey all,
            I have some issues with my laptop as well. The first one is a bios password and that's how I got here in the first place. And the other one is my laptop throttling down to 0.38ghz. Everything runs frustratingly slow. And the fan is running at full speed all the time. HWiNFO is telling me something about prochot-ext, so something's definitely wrong here, although all temps are fine. I have played with windows power management options. Let it run with or without the battery, same goes for the power adapter. Reinstalled windows and drivers and tried many things more suggested in all kinds of forums. But no luck so far. My guess would be either something's wrong with the board or bios, because this issue persists even without windows running or no ssd installed at all.
            Regarding the bios issue, I've read all posts in the RCUnlocker thread and have a general understanding of how it all works. Still, this whole reprogramming topic is absolutely new to me so I'm a little at loss here. I took some pictures of all bios-like looking chips I could find. Which chip does what? I've read that U366 should be the right one. But to be 100% sure, which is the one I have to modify regarding a.) the password issue and/or b.) fan speed and throttling issue and lastly c.) something else I didn't think of? Because some users reported fan speed running at 100% after reprogramming, I wonder if this issue is somewhat related to mine.
            I still have to buy all the necessary tools. Would a cheap CH341A programmer be enough (for winbond and issi chips)? I have an old RaspberryPi 2 if it that helps, although I'm not familiar with Raspbian/Linux. For that chip with those 8 tiny legs I guess a test clip would suffice? And for the other ones just soldering some wires to the copper pads nearby? If removing the chips from the board isn't absolutely necessary I'd definitely prefer not to, because I most certainly would break something (and had to buy a hot air station).
            Your help is very much appreciated.
            • markovic23
              • Sep 2023
              Re: RCUnlocker
              Thank a lot, Admin Password was on U366 under EC, after RCunocking tool everything is fine. Thanks onemore time.
              • alito666
                • Jul 2025
                • 33
                • mexico
                #27
                hi folks, can help unlock this bios admin poassword
                i try rc unlocker but not works 😅
                Model: Hp elitebook 745 g5
                sn: 5CG9322RZH
                mb: TRYPTICO 6050A2945701-MB-A01 (A1)
                • Buzzfuzz2k
                  Bios password removal on a Unowhy dump
                  by Buzzfuzz2k
                  Hi Everyone,
                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                  the Computer is a Unowhy small pc
                  N° UYM6524702229
                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                  My first attempt was to get the bios dump from windows...
                  11-13-2023, 07:37 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • traxformania
                  TONGFANG "GM7TG7P" Bios Password Problem?
                  by traxformania
                  I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                  But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                  I'm trying to reset my bios without success.
                  I tried :
                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                  11-15-2023, 07:32 AM
                • ArkzG
                  [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                  by ArkzG
                  Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                  What I currently have available:
                  - Model: FA506NF (2021)
                  - BIOS chip: GD25LQ16 (16Mbit/2MB)
                  - Tools: CH341A programmer ready to use
                  Does anyone have either a clean 2MB .bin dump of this model,...
                  09-26-2025, 09:34 PM
                • Nopslide
                  HP Omen 15-dh0052nf power-on & bios password
                  by Nopslide
                  Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                  My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                  Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                  04-01-2024, 04:27 PM
